Panasonic Lumix DMC-G1W Digital Camera with 14-45mm and 45-200mm lenses Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What telephoto lens do you recommend for the Lumix G1
Lee Hodgson
Level 3:
  • Panasonic Master 4,810 Answers
  • Posted on Sep 08, 2009
Lee Hodgson
Panasonic Master
Level 3:
Answers
4810
Questions
Helped
1782684
Points
15941
There are four lens's that you can choose from for the Lumix G camera, two of them very expensive and two of them not so expensive.
Have a look at these lens's for an idea >>>>>>>>>>>>
http://www.fotosense.co.uk/slr-lenses/slr-lenses-four-thirds.html?manufacturer=84&gclid=CJPR4rjG4pwCFc0B4wodyDtJIg
Regards.
Telephoto lens stuck
batteries might need charging or try new batteries.
2answers
Taking pictures with x3 telephoto lens
may be there is some problem with your shutter speed and lens
1helpful
2answers
My camera says memory card protected how do i take this off
Eject memory card and flip the white switch. If that doesn't fix problem some cameras can add accidental deletion protection which first needs to be disabled
5helpful
I am looking for a 14-200 lense for my lumix g1
You won't find one with that focal range as it's never been made. A lens with such a range will have far too many optical compromises and will be bulky and heavy, so it's unlikely to ever be made without a major change in materials technology. In 35mm terms, you're after an equivalent 28-400mm lens, and no manufacturer has ever come anywhere close to achieving that on any SLR system. In APS-C terms the equivalent would be an approximate 18-250mm which has been achieved by Tamron/Sigma, but the lens has to be used at modest apertures to achieve acceptable sharpness and exhibits very obvious barrel distortion at the wide angle end and pincushioning at the telephoto end. It's a lens which makes no sense at all as there are better performing digital bridge cameras which are smaller and lighter which can produce an overall similar image quality.
You can only achieve the focal angle you're after by using two micro four thirds zoom lenses or via two regular four thirds models with a four thirds to micro four thirds adaptor. Using micro four thirds models only, you could do this using the 14-45mm and 45-200mm lenses, both by Panasonic.
At the present time, the closest single micro four thirds lenses to what you want are the Olympus 14-150mm and the Panasonic 45-200mm. The first lens has a wide angle to medium telephoto capability, the second has a short telephoto to long telephoto capability.
I suggest that you click here to look at the micro four thirds joint catalog to see what's available.
Sorry you won't find precisely what you want, but I hope that my reply has saved you wasting further time in searching. Please take a moment to rate my answer.
1helpful
I cant read Lumix G1 RAW files with photoshop cs3
It's possible that Photoshop hasn't issued a plug-in for your camera. Check with them. Didn't you get some software with the camera to read the raw files?
Lens
You have a 55mm filter size on your camera, and the accessory lens requires a 62mm camera connection. I think you are looking through a 55mm tunnel into a 62mm lens (over-simplified I know). The black ring is the result, and I don't think you can fix that. Is the telephoto a Panasonic accessory, or a third party item. I think I already know the answer to that. I'd take it back and see what Panasonic recommends - you'd be happier. However, Panasonic has Leica glass (Leitz lenses) so it won't be cheap.
Lens adapters
I received an answer on Flickr (almost immediately!) thanks, anyway!
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
2answers
Portrait
Well if 1x = 35mm, then 4x = 140mm
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
