Question about Lexmark Optra C710 Laser Printer
My optra C710 does not show anything in the display screen...
Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Jan 10, 2008 | Lexmark Optra C710 Laser Printer
Acer c710 chromebook screen blinks
Plug a monitor to the vga port or a tv onto the hdmi port and start the laptop.
Still blinking but you can use it through the other screen?
->Cable inside the machine for the lcd screen damaged.
If you don't see anything on the second screen try CTRL+F4 to mirror the main screen if nothing happen then the video module is dead.
Feb 08, 2014 | Acer New C7 C710-2847 Chromebook 11.6"...
84 TRANSFER BELT EXHAUSTED
84 TRANSFER BELT EXHAUSTED indicates that the transfer belt is exhausted and must be replaced. A new transfer belt must be installed to clear this error message. For assistance, you can contact Lexmark technical support or your authorized service provider. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark Optra C710 Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Lexmark C710 MFP jams 200.04
Things to try:
1. Look for a piece of paper jammed in the rollers. 95% of the time that is what it is.
2. You have a paperclip or paper wad in a feed roller or gear.
3. The hard and easy way to find the jam is to feed a piece of paper and then before it feeds all the way through unplug power to the machine about the time where it usually jams.(several times may be necessary) Then follow the piece of paper to where it jams to find the location of the clogged paper.
Sep 15, 2009 | Lexmark Optra C710 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Need service manual for C710.
Hi Matt, i'm not sure how you tell how much life is left, but i know that transfer belts on other laser printers usually go on working way beyond their (built in) redundancy counter. It may be possible to reset it with a service code which i will try and find for you. I have the same printer and have a number of new transfer belts for it so it might be eaisier (although not necessary) to just replace it. Maybe having put a new one in you could swap the old one back until quality gets too bad and then use the new one by which time i may have found a reset code. I can let you have a new one if it helps. Garry
Mar 04, 2008 | Lexmark Optra C710 Laser Printer
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Feb 15, 2008 | Copystar CS-2030 Copier
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Lexmark Optra C710 Laser Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
