Question about Kenmore Dryers
How do you replace the cable that holds the door open
The door flops opened, it doesn't have a cable or spring to keep the door opened. I found a broken cable inside the door, and ordered another one, but I can't figure out how it attaches. Help
  • 612 Answers
There is a plastic plug where the cable goes into the door. Take a putty knife or flat screw driver. slide it in between to plug and door. Then pop the plug out. The plug it's self is what holds the cable to the door. Do the same on the unit end. I use a putty knife because it's easier to get behind the plug.
Please rate solution
Posted on Sep 08, 2009
Interior driver side door handle does not open the door and doesnt lock.
remove interior door card and inspect door handle rod to lock mechanism make sure it is connected both ends
Oct 06, 2015 | Cars & Trucks
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
Car Door Diagram
Check that the spring on the notched plate is not broken and fallen out.. It may be possible to get a new spring and place it back in It may be difficult to do but with some thought it can be done.
May 25, 2013 | 1998 Holden VT Commodore
Horrible noise when spinning
this could be a fuw things doing this,,,it could be the drum bearings worn out or the suport springs broken,,,to check the drum breaings open the door and try to lift the center drum a little with your fungers if there is flop in the bearings there worn out they may also rumbel if you spin the center drum by hand,,,to check the suport springs open the door and lift the drum up if there is a lot of lift and the drum is saging to one side the spring may have broken of just poped off,,,wip the top off and you should see two strong springs holding the inner drum up, if one is missing look under the drum for it, or fit a new one?
Nov 25, 2010 | Zanussi F1045W Front Load Washer
I have a stanley garage door opener model 1200.51 which is chain and cable driven. The problem i am having is each cable came off and i want to know how to reattach them.
The most important thing is to understand that the door spring can KILL YOU. If you are not absolutely certain that you know what you are doing, call a garage door guy. Many poeple get SERIOUSLY hurt.
So, you need two perfectly fitting rods to fit into the spring tightening end of the spring..
Release all spring tension. Release the opener.
Level the door with shims if necessary.
Install the first cable and turn the spring main rod to hold tension.
Put a vice grip on the main rod to keep it from unwinding any more
Release the 2nd cable spool and thread the other side cable. Turn the spool to have the same tension as the other cable.
Then wind the spring about 6 revolutions. (35 flats or tool insertions).
Verfiy the cable is still threaded correctly on both sides.
Correct spring tesnion is when the door will stay at 1/2 closed.
REconnect the opener and good to go.
Nov 10, 2010 | Garden
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Small spring found
that spring is the door open hold spring.
Mar 13, 2009 | 2001 Jeep Grand Cherokee
Replacement for the spring loaded door on my tower
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Dec 30, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Dryers Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
