Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Mine is all red
Sometimes when I turn the set on, it's all red
    President:
  • 1,447 Answers
It is problem color ic or dry solderd
Posted on Sep 08, 2009
  • Sazeed Computer
    Sazeed Computer Sep 09, 2009
    it is problem dry solder in color ic or video section you go to a service centre they solve your problem
I have an LG plasma tv model # 42pg20-ua. Everytime I try to turn it on the tv keeps clicking turning from blue to red. Tv never actually turns on. I keep trying to turn it on, but it just clicks and...
that is usually a t-con board or video card. ebayers usually have those parts reasonable.
that's how I fixed one of mine.
it could be the power board which is the costlier part.
Aug 01, 2017 | Televison & Video
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
My 2000 ford contour se would not start....put a new battery but still.....
does the red light near the clock flash . This is the anti theft system. Mine sometimes wont start if this light is on or flashing. I sometimes turn the key over to the other side and it starts.. You may have an issue with the anti theft system an or your key may need re-programming. If this is not the problem than there may be ignition issues. Check the fuse panel under the hood for a bad relay or blown fuse. The panel is beside battery. The other fuse panel is under the steering wheel check it also for bad fuses. You can test the fuses with a multimeter set on continuity or resistance..
Mar 15, 2010 | 2000 Ford Contour
52LG70 sometimes turns off and on periodically
I had the same problem. I changed the 4-3 setting on the motorola cable box. Turn off your cable box and press menu. My 4-3 setting was set to auto. If you turn it off, you lose the 4-3 aspect on most channels. I changed mine to 480p and so far it seems to be working. Worth a shot.
Sep 07, 2009 | LG 52LG70 52 in. LCD HDTV
Turn on of unit sometimes does not light lamp. Red/Green flashing light, then turns on the next time. (Using button on unit) When using remote, can sometimes get it to turn on the first time (without going...
I'm having the same issue now. Did you ever figure out what was wrong with your unit? Was it a bad lamp? Mine is only 9 months old, low hours, but perhaps a bad one? Can't understand why it would light sometimes but not others.
Jul 01, 2009 | Mitsubishi HC5000 LCD Projector
32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
It could actually be quite a few things, loose wire, loose solder piece, bad crt's/picture tube, bad system board, or others. It's would have to be diagnosed with testing equipment. It will probably cost you another 150-200 for the new part to be put in.
Jan 28, 2009 | Televison & Video
Don't know how to set-- need manual
I have one but no manual. Mine you just turn the dial in the middle clockwise to set the time. You put white stops on where you want the timer to turn on. Red where you want it turn off. Hope this helps.
Oct 16, 2008 | Intermatic 10A OUTDOOR TIMER
Ps2 wont turn on
it might be the disk...when the ps2 cant read the disk sometimes it justs turns off...mine does the same thing....when i put in a another disk it works fine
May 17, 2008 | Sony PlayStation 2 Slimline Console
Green screen
Open it up and check to see it the circuit board attached to the tube is seated all the way down. Both of mine were not attached that well so I pushed them back down and have not had any problems since.
Nov 07, 2007 | Sanyo HT30744 TV
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
