Question about Freezers
GE Profile Side by Side - PSS26lsrc - Unit whistles - like wind noise. Also does not produce as much ice as it used to. Need to pres 'quick ice' to get it to make ice.
  • Pam Kearney
    Pam Kearney Sep 08, 2009
    The noise comes from the area at the top of the freezer - not the bottom where the motherboard is......
  • 4,070 Answers
I know of two things which can cause the noise. Since it hasn't always made the noise I would guess the motherboard is making it. Try to pinpoint the noise. Your motherboard is on the back. Part 801 on this diagram. If this is where the noise is coming from and you can put up with the noise, you can wait till you have more trouble with it. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PSS26LSRCSS&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-R-SERIES&diagramPageId=00009&componentDescription=SEALED%20SYSTEM%20&%20MOTHER%20BOARD&documentId=G0503214&backToLink=Return%20to%20Sub%20Components%20list
Another cause I've seen is because of the unique shape of the condenser coil. With the air pulled through it it can make a noise. It may help to clean the coil which may also help the ice situtation. It's part 730 on the diagram.
Posted on Sep 08, 2009
  • Charles T Nevin
    Charles T Nevin Sep 08, 2009
    In the freezer near the top is the evaporator fan and it could be getting partially blocked by ice buildup causing the noise you're hearing. Or the motor it's self can be making the noise because of wear.
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
On the freezer side their keeps being water frozen in bottom
The drain to it is stopped up or the heat strip that melts the ice has gone bad. When working right, the water should drain out. The water goes into a pan under the freezer and evaporates.
Jan 27, 2013 | GE Profile Panel Ready 24.6 Cu Ft White...
GE Profile Arctica not making ice
Check to see if the fuse for the icemaker is blown. Check to see if the linkages are moving. Check the activation motor is getting power.
Jan 20, 2013 | GE Profile Arctica Customstyle...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
Ice maker not working properly & Ice cycles in freezer
THIS IS WHY PEOPLE USE THIS SITE.ORDINARY PEOPLE NEED FRIENDS TO HELPOUT....
find an elderly person in your area that needs help, not charity.the feeling is priceless...
Feb 11, 2010 | Freezers
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
GE Profile side by side refrigerator-freezer PSC23SGNABS
Hi sckk,
ngafm at your service,
Your indoor ice and water keeps getting iced up.
There is an air leak somewhere between the ice and water dispenser on the door and the freezer!
there are many places that this may be. But usually the spring loaded door where the ice drops out to the door ice machine!
It takes a good tech sometimes a couple visits changing a couple of parts till he gets it.
There is no sure fire way to diagnose which part is the culprit thats leaking air.You need an experienced tech that eyeballs it and knows what parts to choose first to be replaced.
The air leak almost microscopic to the eye.
Sometimes you take ice from the door and the crack only closes full some time after wards. Then the tech comes the next day and sees nothing. Or it is intermittent problem!
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
please give me a goo rating before you sign off.
Thank you.
Sep 09, 2008 | Freezers
Freezers Logo
253 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
