Question about Nintendo DS Lite Console
Ds lite charge, but green lite will not come on
After replacing bottom screen and F2 fuse my ds lite came on for a minute and then both screen went blank. now it does not turn on at all. everything double check. when i plug charger i see orange light.
  • 51 Answers
You have damaged the L2 fuse just below the power button. It is vary delicate and easy to knock of off its placement despite being soldered in.
Double check this fuse to make sure it is still in place and soldered to the contacts on both sides of the fuse.
Posted on Sep 16, 2009
SOURCE: DS Lite does not power up
I have the same problem with my sons DS Lite. I called Nintendo at 1-800-255-3700 which is in your Manual, my DS Lite is not even a year old. They are sending me a refurbished unit, which is next to brand new for free. It comes with a 1 year warranty. When the new one arrives you send back the old one to them. They pay for postage and everything. I guess this is better than not having a DS at all and who wants to spend the money on another. Give it a try. And as for a diagnosis of the problem they think it can be a electronic component inside the unit but they are not sure. Hope this helps ya !!! Smilie
Posted on Sep 11, 2007
SOURCE: nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
i had the same problem, our voltage here is 220 what i did was to plug my charger in a 110 volt avr. now its working fine so far.
Posted on May 04, 2008
SOURCE: DS lite green light comes on, top screen flash,then switches off
I have exactly the same problem. In my case the bottom screen only flashes for a second before everything goes dead.
In the meantime I may have killed D7 (close to F2) which made the situation worse since when I power on now nothing happens at all.
Have you been able to fix it yet?
Posted on Jun 27, 2009
  • 56 Answers
SOURCE: Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Brandonmxb
  • 115 Answers
SOURCE: my nintendo ds lite console does not power on. I
Well I attempted to help you but you rated me horrifically even though I answered you question.
Posted on Dec 13, 2009
My DS wont turn on so I try to charge it the orange light comes on but eventually it turns off an suggestions?
When you say it doesn't turn on does the green light come on at all?
If the green light stays on for 1-2secs then you should see one of the screens flash, if that happens then you will need to replace the screen that doesn't flash. If you need to replace the top screen follow this guide, or if you need to replace the bottom screen follow this guide.
If there is no green light at all then the chances are the "F2" fuse has blown. To replace the fuse follow this guide.
If you need help taking the DS lite apart follow this guide.
The guides are written by me so if you need any extra help or if you have any more questions don't hesitate to contact me.
Hope tis helps.
Regards,
SOD69
Feb 11, 2010 | Nintendo DS Lite Console
Tip
DS Lite fuse replacement F1 F2
Does your DS lite refuse to charge?
Does the orange charge light not come on at all?
Has your DS stopped switching on with no green light at all?
Well this is the guide for you.
Remove the DS lites base plate (for a guide on how to do this see my other tips and tricks) and locate F1 and F2 (see pics)
F1- Charging fuse. Change this one if you have the following issue:
Orange light doesn't come on at all when the charger is inserted and a battery connected.
F2- Console power fuse. Change this one if you have the following issue:
The DS lite console charges but refuses to power on.
If you find that the DS lite console neither charges or switches on i.e. no lights come on, not even for a brief time you can replace both fuses and it "should" resolve the issues, however, I cannot guarantee this as there could be other factors for the lack of power e.g. water damage.
To change a fuse you need to first remove the old one, do this by desoldering either side of itand remove it from the board.
Putting the new fuse on is a little trickier, you will need to hold the fuse in place with a small enough item that will not get in the way ofthe soldering process such as a cocktail stick or tweezers. Solder either side of the fuse to the board taking care not to make a bridge* with the solder. Give your newly laid fuse a test to be sure you have done it correctly, put the DS lite back together and then your done.
*Bridge - A solid connection made over or around the fuse thus bypassing it.
I hope this helps and I have to say that I take no responsability for any damage that may occur whilst following my tips/ guides.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
Tip
DS Lite stopped working. Green/Orange light Flicker On then Off.
Has your DS lite stopped working? does the green/orange light momentarily stay on? Here are a few tips to help you on your way to repairing your DS lite.
These are the three top reasons for the above faults:
1) One of the screens is either not correctly connected or has devlouped a fault... If one of the screens flickers after you switch it on and just before the green light goes out then the screen that doesn't flicker is causing the problem, firstly try reconnecting it and if that doesn't work you will have to replace it, both screens are avaliable for a reasonable fee on ebay, search for either "DS lite top screen" or DS lite bottom screen".
(if you need help with replacing the screens check out my other tips and tricks I have issued on here).
2) Locate the inductor labled "L2" if this is missing then you will need to either solder it back on if you can find it or else you can buy another one again on ebay for a reasonable fee, search for "DS lite L2".
3) If both the above fail then chances are you have blown a fuse, if you can charge the DS then it is not your "F1" fuse in which case you will only need to replace the "F2" fuse, firstly desolder the old fuse and then solder on the replacement fuse, this should solve the issue. If however the charging light stays on for a very brief time (i.e 1-2secs) then you will have to replace the "F1" fuse, locate the "F1" fuse and follow the sames steps stated for the "F2" fuse. These fuses are also found on ebay, search for "ds lite fuse" and buy the quantity you require.
If you don't have access to soldering equipment or are unable to solder these very small parts (i.e fuse dimensions - 1.5 mm x 0.8 mm and the "L2" inductor dimensions - 2.5mm x 1.8mm x 1.8mm) The is a product called wire glue which is avaliable from ebay (located in the USA) which is fantastic as it is a glue with conductive properties.
You may find guides that tell you to "bridge" the fuses and "L2" inductor but I would strongly advise against this, afterall they are there for a reason and just think what damage would have happend if that fuse hadn't have blown.
Here is an image for the location of the fuses, also if you look just under the power switch you will see the "L2" inductor:
http://www.xdupe.com/assets/images/nintendo_ds/tutorials/ds_lite_fuse/usg-cpu-x3_fuses.jpg
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Unit won't turn on !
This could be due to several things, the main ones being:
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Orange light for a second then nothing
Possibly a bad charger? Try getting a new one.
Jan 27, 2010 | Nintendo DS Lite Console
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Ds broken? Green light blinks, bottom screen flashes, turns off.
You will have to open it up and desolder the fuse that says, F2, and then solder a small piece of wire onto the two spaces that the fuse sat on in order for you to bridge the fuse because it's probably blown. Then try powering it up. If it works, then you have just repaired it. If it doesn't then there must be another fuse that is blown. Try testing the fuses with a multi-meter. I am guessing that it could be the F1 fuse if the F2 fuse was also the culprit. Do the same thing to bridge the F1 fuse and then it should work.
Feb 25, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
222 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
