Question about Home
Is it possible to drill into a Kohler cast iron shower pan, without cracking the porcelain? I need to secure a track for a shower door. -- Thanks!
    President:
  • 1,564 Answers
Yes you can but you've got to buy a special bit. Porcelain will dull a brand new bit in seconds. You've got to get a carbide tipped or concrete drillin bit. Also while you are making preperations to drill put a piece of wide masking tape over the spots to be drilled. Don,t push down too hard and let the drill do the work. Good luck.
Posted on Sep 08, 2009
The porcelain spark plugs keep on cracking when the car is being used
Is the porcelain "cracking" or are they getting "carbon-tracked"? (see example photo of carbon-tracked plug below).
It is common for carbon-tracking to occur if your original plugs were carbon-tracked and you replace the plugs without replacing the wires. If the plug is carbon-tracked, the boots on the wires or the coil boots (coil-on-plug ignition) are also carbon-tracked. If you do not replace the wires or the coil boots, the ignition will still misfire by following the carbon-track on the inside of the boot. This will cause your new plugs to also be carbon-tracked within a short period of time (days or weeks).
There is no reason I can think of for the porcelain itself to actually crack other than faulty installation techniques or possibly, cold liquids getting poured on extremely hot plugs.
May 11, 2012 | Buick LeSabre Cars & Trucks
Will Kohler Disposal Flange K-11352 work with Kohler Sink K-5924?
Kohler makes their sinks standard, and most all sinks are the same size hole, yes it will fit.
May 22, 2010 | Kohler Plumbing
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
What type of grids are the best and why, either porcelain over cast iron, or just cast iron.
The porcelain is easier to clean,and wont rust,but it can also be chipped off if dropped.Its really a personal choice after that.there is nothing wrong with the plain old cast iron ones.
Jun 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
Can a hairline crack in a porcelain bathtub be repaired?
If your tub is porcelain over cast iron and the cast is not cracked your ok. If the cast is cracked then the chances of the crack continuing are great, more so with any vibrations and changes in weight distribution.
Feb 19, 2009 | Home
Home Logo
469 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
