Question about Airlink 802.11G Wireless 4-Port Router (rt210w)
AIRLINK+ can't login to config, It doesn't accept user/pass I try to enter user./pass. many time. Please help !
  • 4,281 Answers
First press RESET button it is in back side of router press it for 10 seconds so all settings are defaults.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Let me know if you need more assistanse.
Thanks.
Posted on Sep 08, 2009
How do I set up my login to just tap the picture and not have to use a password
Going to assume win 8:
  1. windows key + R
  2. type netplwiz and press enter
  3. Select your account and uncheck user must enter pass to use computer
  4. enter your password to accept the changes.
Enable direct Windows 8 login without password prompt
Jun 19, 2015 | Computers & Internet
Pass word
try holding ctrl+alt+del keys at the same time, and enter user Id administrator and password blank, then create a new user.
Oct 27, 2008 | Microsoft Windows XP Professional With...
Awlh3026 on dell dimension 8300
here's a link at end of this message u can use to read or obtain the 3026 card's manual. or just go to manufacture's site ,,airlink.com, click tab to go to support page and do a search for ur model , then find and download the zip file for the OEM drivers and setup/config utility, extract the compressed file to ur hard drive, be sure u pay attention as to where it is going to be extracted to, then turn ur PC off, power down all the way ,, insert card into the board slot, secure it properly,, restart PC, and when new hardware install screen pops up for the auto detection asking u if u want to install drivers, be sure to click cancel, do not continue with install at this time,,, the window will close,,,then go to folder where u extracted the software files, click setup icon, when it finishes,it will close and restart PC, when it reboots, u should see the Windows lan network connection icon on lower right of screen.. left click it , go to config tab, and remove the default check from box on upper left corner of that window to disable windows from doing any of the card install or config of the wireless connection, Very important**,,, note,,, absolutly no way,, that, both of the utility programs can be enabled or run at same time,, will not work with 2 bosses,, meaning both the airlink setup/config utility and the default windows networking program.,,, this link to read smaller 4 page manual it will explain in detail,,, or u can also locate and download the original larger 20+ page instruction manual at the airlink site as well,,, I just installed same card into a Dell Dimension 8200 last night,,,, had a hell of a time myself,, totally failed at figuring it out per the usual/norm standard installs,, that is,,until I finally did the research,, determined the error was made when initially installing the drivers at detection using the plug n play from windows instead of clicking "cancel" button , as required,,at time of detection of card...then doing the complete install, setup, . and config using only the downloaded OEM Airlink software. Be sure to download the awlh3026_util_drv_winme/xp zip file download that is clearly marked for XP operating systems, two are aailable for xp,, u will need both the drivers and the utility as well as the manual download,,, and only trust software downloads if obtained from the official manufacturer's site ,, heres one set of instruction manual u can go read right now without downloading it to help explain quickly
hope this helps
http://manualslib.com/manual/206893/Airlink-Awlh3026t.html
Sep 27, 2012 | Airlink AWLH4030 (658729080430) 802.11g/b...
My login doesn't work-after i entered my email address and password I wasn't able to login
Try using Facebook's account recovery page:
https://www.facebook.com/recover.php
That should help you recover your account if you've forgotten your login user name and password, or had your account hacked.
If that doesn't resolve your issue, try clicking the "I can't identify my account" link at the bottom of the page for more help.
If this doesn't help, please comment with your browser and Windows version, any error messages you're receiving, and any other relevant information.
Please leave feedback if this was helpful, thanks.
Mar 31, 2011 | Facebook Social Network
Please help me out,although for sometime now i have not open my yahoomail box,but for the past two days now, whenever i type www.yahoomail.com and send it,it will not open but i will only see...
Yahoo Mail and the URL that you have provided is just the same
"https://login.yahoo.com/config/login_verify2?&.src=ym" - this URL is a link where you can access your Yahoo Mail. You may enter your user name and password. Then click on login.
Just login to it, and you will see your Yahoo e-mail.
Thank you!
Sep 12, 2010 | Yahoo Mail
INSTALLED DISK BUT IT GIVES ME WRONG PASS CODE WHEN I TRY TO LOG IN ON MY LAPTOP. i AM USING THE CODE THAT CAME WITH THE ROUTER AND HAVE CHECKED MANY TIMES AND IT IS CORRECT. IT SHOWS AVAILABLE BELKIN ON...
hi,
Reset your router will help you.. Resetting will cancel your all configurations. and will accept your default password and user name (i.e. admin) After resetting config your router again.
Hope this has helped you thanks
Jun 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Cant Login into fixya expert utility
Make sure the alph cAsE is correct and there is not a space before of after your user or pass.
Apr 04, 2009 | Computers & Internet
I can't login in to change time or phones to ring.
Try feature * * config (266344) then admin (23646) that should get you into progaming
Mar 18, 2009 | NorStar T7316E Corded Phone
Can't get my yahoo mail because it's not accepting my password and I can't verify my identity because it's not accepting my pet's name. Please help!!!!!!!!!!!!!!!!
SOMETIMES This happens because somebody tried to make a large amount of attempts to guess your password and enter your account. Many times, it's not actually someone trying to access the account, they just know that by sending a huge amount of requests, they can cause the user problems by having their account closed.
The servers understand that a human can make about 5 or 6 attempts a minute, this would be normal if you had forgotten your password or made a typo etc... and at this rate, it would take 18011 years to guess your password.
An automated program however, could make 1000s of requests a minute or even more! Its when the server experiences these numbers, for your own security, it locks your account.
Fix:
First, visit http://login.yahoo.com/config/login Don't Worry! The first attempt will fail, say incorrect password or something. It's the second attempt that matters. What you will see this time, is that you have a word verification. This is a secure system by which only humans could be making the request, bots cannot see the text, they see encrypted numbers.
For some, this is it, the account will log in again! For others, it's not so. You have to wait up to 48hrs for the account to come back.
Jan 06, 2009 | Yahoo Mail
Airlink 802.11G Wireless 4-Port Router (rt210w) Logo
301 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
