The remote works but not on the AC unit. We bought 4 of the same type of AC units and one of the AC stop working with the remote it came with. THe AC works on forced operation mode so there is nothing wrong with the AC
  • ceasar m Jan 01, 2012
    does the the other remotes work on each other ? if so change the batteries on the non working remote , then with a tooth pick push the reset button normally on the front or face of remote ..
  • 20 Answers
There is inside(front) the AC unite remote pcb has to be replaced or repair
Posted on Sep 08, 2009
How can i either modify my AC unit to work without a remote control or program a different remote control to be able to switch settings on my AC unit
What type of unit? Most units can be hard wired to a regular thermostat but you will need the owners manual to reset the program in the circuit board. The manual can be downloaded from the internet.
Jul 20, 2014 | Heating & Cooling
Goodmans gtvl26w17hdf
first and foremost,do you know how to operate your universal remote control?refer to it`s manual...look for that unit`s brand if it is also included to the unit that this remote control can command.if it included,look for the codes below it and try to follow the steps/methode of using this codes.example;:; 1-press the search button for 3 seconds until the led stop blinking or start to blink 2-press the unit(tv`s,dvd,ref,a/c,etc...) 3-put the 3 or 4 codes ,4- etc....
Jan 31, 2014 | Televison & Video
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
My airconditoner window AC suddenly stopped working.. I had checked the power supply also, with the remote also its not working..plz help
Not much you can do unless you can do. Did you checked the outlet. Was the AC unit powereed up so the remote would work
Aug 20, 2009 | Heating & Cooling
Remote doesn't work.
John I suspect that your remote sensor reciever on the ac unit is bad, you may need to replace it. Quite simple two screws and a plug in fitting.
May 04, 2009 | Heating & Cooling
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Heating & Cooling Logo
    237 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
