Question about Samsung SMH7178STD Microwave Oven
I need parts. The plate and ring below it are both broken
  • William Miller
    William Miller May 11, 2010
    NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice.
    William E. Miller
    prototech@usa.net http://www.microwavedisplay.com
  • 71 Answers
You can buy that parts at your nearest samsung authorised service center in your area.try to search in the internet the nearest ASC in your location.
Posted on Sep 16, 2009
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Glass plate does not go round
Take it out and take any other 'ring part' below it out as well until you only see the small pivot-thingy, then turn the oven on; when you don't see it spinning, motor failed completely and it's probably best just to buy a replacement (second hand or new).
If it does spin, it might be that it's burned out (i.e. not having enough torque anymore to spin the pivot including the glass plate (as the plate adds quite some weight) or jus that some of the plastics fittings are broken. In the later case you might be able to 'fix' it, either by fiddling some wires, glue or whatever. If the motor's just burnt; it's probably best to get a replacement microwave as replacing the engine is probably as expensive as buying a secondhand microwave ...
Oct 17, 2014 | Microwave Ovens
Plate wheeled support broken
You will need to go to Sunbeam to get that part, if it were a plate easier to find. ebay is a very good source for microwave parts, also check out a microwave repairman.
Mar 08, 2012 | Sunbeam Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Noisy turntable
Hmm .. if it is the turntable that is making the noise, then remove the plate and the guide ring. Wash all the parts, and the track that the guide ring sits in and then all back together ..
May 12, 2010 | Microwave Ovens
The glass plate will not rotate when trying to heat up your food...
Sounds like either the turntable motor has seized or that the shaft of the turntable motor has broken off inside the roller ring. You may need to chek with your local De'Longhi repairer.
Nov 29, 2009 | DeLonghi Microwave Ovens
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
Won't Turn on
The turntable motor on the base of the machine may have failed. Take the plate out, put a small plastic jug of water in the microwave corner (out of the way of any roller), set for 30 seconds, and see if the spiggot/roller ring rotates. It also could be the spindle of the turntable motor has broken off in the spigott/roller ring.
Mar 21, 2009 | Microwave Ovens
Rotating ring
The part number is 5889W2A014C.
It's available from www.microwaveglasstrays.com (toll free 1-877-894-0035)
Aug 26, 2008 | Sunbeam SBM1000 Microwave Oven
Microwave plate doesn't fit on cog?!
I know this is probably DUMB of me to say, But some with this type of turntable arrangement, The ring would only set one way. The ring did not turn, but rather the wheels faced up and rolled with, and supported the turntable.
Jan 25, 2008 | Danby DMW1145 Stainless Steel Microwave...
Microwave Ovens Logo
43 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
