Question about Cycling
Diagram for the tension belt on a Body Guard 955 ErgoCycle
I need a repair diagram for the tension belt on the Body Guard 955 Ergocycle. I don't know how to put it back together properly. I think I have all the parts.
I also need help with this, if anyone can help us solve it it would be much appreciated
Posted on Nov 04, 2009
99 kia sporage timing marks
Hi there:
Check this information...
Crankshaft match marks
Align marks on timing belt pulley and pump body.
Camshaft pulley alignment marks
  1. Align marks on camshaft pulleys with alignment marks on seal plate.
  2. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  3. Loosen tensioner lock bolt.
  4. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  5. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  6. Apply a force of 22 lbs to timing belt between camshaft sprockets.
  7. Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  1. NOTE: Replace tensioner spring if timing belt deflection is excessive.
  2. Timing Belt Installation
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 14, 2012 | Kia Sportage Cars & Trucks
1997 pontiac bonneville se
There is a tensioner pulley attached to an arm.
Release the tension on the belt by undoing the pulley arm bolt, the belt will have enough slack to slide off the pulleys.
To put it back on, you find the diagram on the radiator guard or under the hood.
Sep 01, 2008 | 1997 Pontiac Bonneville
Problem with 99 kia
Hi there:Check this information...
I need 3 parts for the Bodyguard 955 ErgoCycle. I need a friction strap, 1230 mm; a fixing hook for friction strap; and a lock spring. I can't find a picture of one part called a Flywheel cpl, white...
If you can't find it with a Google search for "Bodyguard 955 ErgoCycle parts" then coming here is not going to do you any better. Note below that "wvlyon" was looking for similar parts in 2010 without luck.
Jun 27, 2017 | Cycling
We need to know where the tension pulley goes and we need a diagram to show us how it goes in
You can view an extensive list of dryer belt diagrams at the following website:
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help
The diagrams are listed by manufacturer and model. If you still need assistance in determing which diagram to use, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If the link does not work for you, go to repairclinic.com and click on the "Get Repair Help" link at the top of the page. Select "Dryer", followed by the "Click here for belt installation diagram" link.
Nov 23, 2010 | Dryers
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Serpentine belt diagram for 1996 audi a4 quattro v6. I can't find a proper diamgram and install procedure, can you help?
Ribbed Belt: Service and Repair
Ribbed Belt, Removing and Installing
Ribbed belt, removing and installing
CAUTION: Mark the direction of belt travel before removing, using a crayon or marker. Reinstalling a used belt in the opposite direction
could damage the belt
Note:
There are two different types of ribbed belt, identified as versions A and B.
Ribbed belt versions, identifying, refer to Application and ID
Removing
Old version A
- Remove ribbed belt guard.
- Loosen ribbed belt tensioner using 15 mm wrench and drift 3204.
- Remove ribbed belt.
New version B
- Using 10 mm hex socket wrench, turn downward in direction of arrow to loosen ribbed belt.
Installing
Install in reverse order of removal, noting the following:
- Place ribbed belt over drive pulleys and idler roller first, and onto tensioning roller last.
- Remove drift 3204.
- Install ribbed belt guard.
Sep 24, 2009 | 1996 Audi A4
Bicycle type: bodyguard ergocycle 955 The buckle on the tension belt broke this is an old bike but I LOVE IT! Any suggestion ore help as to where i can get a belt and a buckle from is greatly...
I have the same issue. I love this bike and want to fix it. Did you get any help on where to find a new tension belt and buckel
Sep 10, 2009 | Cycling
1999 kia sportage timing marks
dfd3ea1.gif Crankshaft match marks
  8. NOTE: Replace tensioner spring if timing belt deflection is excessive.
Jul 26, 2009 | 1999 Kia Sportage
Peugeot 206 (manual, 2002) - fitting a new fan belt I have removed the old belt and want to know how to thread the new one. Is there an online diagram I can reference? Also, I need to locate the manual...
for your car, you need a repair manual for the diagram if it's not under your hood on a decal. And yes, you may need a special tool for the tensioner. see if Chilton has a repair manual for your specific car.
Oct 13, 2008 | Peugeot Liberte Cars & Trucks
Cycling Logo
1,381 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
