Question about Refrigerators
Refrigerator gets warm inside about once a month because the coils inside the freezer section get covered in thick ice and has to be defrosted .
  • capt2duck May 11, 2010
    Defrost timer or defrost thermostat is probably bad. Is this side by side or top freezer or bottom freezer?
  • 93 Answers
Your defrost cycle is not working right. If you have a mechanical defrost timer then replace that and the defrost bimetal in the freezer. They are both cheap. If your refrig has a control board then you have to replace that instead, because that is what controls the defrost in an electronic defrost. Either way always replace the bimetal thermostat in the freezer. It is cheap insurance
Posted on Sep 13, 2009
Freezer does not defrost automaticly, its full of ice??
This is intended as a guide to defrosting a refrigerator that has the freezer on the top. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Replace all pieces and wires to their original positions and then restart the refrigerator. It may take a bit for everything to cool back down, especially in warm weather. Now with everything working properly you should be trouble free again.
Take care in solving the problem....
Sep 16, 2011 | Whirlpool GB2SHDXP Bottom Freezer...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
Ice has formed on the bottom of the freezer about 1/4 inch thick. Refrigerator section is hot.
Most likely the cause of your problem is a faulty defrost system. The ice is building up on the evap coil in the freezer, so the air from the fridge can't get cooled by the coil. The common failures are the defrost heater burning out, or a defective defrost timer if yours is an older model. The heater is mounted on the coil. To get access, you will need to remove the back panel in the freezer. There you will find the coil and heater. You will need to use a hair dryer to melt the ice off the coil.
Jun 30, 2011 | Kenmore Top Freezer Refrigerator
I need to defrost my sub-zero 650. Can you give directions?
This is intended as a guide to defrosting a refrigerator. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
Good luck
Aug 08, 2010 | Sub-Zero 650 / O Bottom Freezer...
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
I HAD THE SAME ISSUE EVERY FEW MONTHS. REMOVE THE BACK COVER IN THE FREEZER, YOU WILL SEE A SILVER TRY WITH MOST LIKELY ICE IN IT. THAW THAT ICE AND THERE IS A DRAIN HOLE IN IT. USING A HAIR DRIER GET THE TUBE TO THAW ALSO. ONCE WATER IS FLOWING TAKE A PIECE OF 12 GAUGE BARE COPPER WIRE AND SLIP IT ABOUT 18" INTO THE HOLE. WRAP THE OTHER SIDE OF THE WIRE AROUND THE WIRE COIL YOU SEE WHICH IS THE DEFROSTER. WHEN IT WARMS IT WILL HEAT THE WIRE ALSO AND KEEP THE DRAIN CLEAR
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire frs26znhd1
you have a bad defrost thermostat or defrost heater the way to get to both of these is go inside your freezer section and take off the panel on bottom the defrost t-stat is on top of the coil clipped to the line and the defrost heater goes up under the coil
Sep 29, 2008 | Frigidaire FSC23F7D Side by Side...
Freezer coils get covered in ice about once a month
If the fan is running, replace the defrost thermostat!! Make sure the heater is working... see blog on testing the timer and heater!!
Good Luck!!
Aug 17, 2008 | Frigidaire FRT18G5A Top Freezer...
Bottom freezer coils freezing up
DEFROST PROBLEM CHECK YOUR DEFRST HEATER,DEFROST T-STAT=LOCATED BEHIND THE PANEL BOTH ARE LOCATED ON THE COIL WITH A OHMETER OR DEFROST WITH HAIR DRYER IT WILL HELP FOR 10 DAYS OR SO.
Jun 25, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
