Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Samsung DVD-HR730 Freezes.
Hello, my Samsung DVD-HR730 was working fine up until a couple of days ago but, now, when I switch it on the Front Panel Display says LOAD but does not actually come on. Previously it would display LOAD for a few seconds and then this would disappear and the unit would be ready to use. Pressing buttons on both the remote control and on the unit itself makes no difference. What has gone wrong and is there anything I can do to fix this problem?
SOURCE: dvd hr720
Had a similar problem after loading a suspect dvd (one I had burned myself) Could not do anything - stuck at loading. Don't remember if the fan was running. From what I have read these units are touchy to bad disks (DVD or HDD) If yours has a DVD inserted try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Posted on Jan 12, 2008
SOURCE: Samsung Dvd R130
press intro key for 5 seconds
Posted on Apr 01, 2008
  • 3 Answers
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Posted on Sep 22, 2008
SOURCE: front display says "SAFE" and now nothing works
hold "info" button for ten seconds
Posted on Oct 03, 2008
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
BD-P1600 will play DVD-R with no problems up untill the last chapter of a movie then the picture freezes up and wont finish playing. is there a solution? Updated firmware about 3 weeks ago.
Either the Laser needs to be cleaned or it needs to be replaced. To clean, purchase a DVD player cleaner that uses fluid. roughly 20.00 run it a couple times and test. If it works, great. If it doesn't, replace the unit. It's cheaper than the repair. Hope this helps
Jan 13, 2011 | Samsung BD-P1600 Blu-ray Disc Player
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Need to unlock the region code so that I can play Australian DVD's on UK machine
Go to videohelp.com and search on the model number - the sequence of remote control keys to press to change the region code is there. It worked well for me, so I could play US DVDs on my UK region machine.
May 08, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Hi The DVD player on my Samsung DVD-HR730 has stopped working. I can record onto the HDD and playback no problems but can't play any DVD's (even ones I've watched on it previouly). They're definitely...
Hello Shar2201
Try to clean the read laser and the laser pickup, by using a DVD cleaning disk. If this does not work you may have a misaligned laser or pickup. In which case you will have to take the unit to a shop to have it aligned and cleaned. You can try to do this yourself but if you do not have the proper equipment, you will do more damage then good.
Thank you,
Shuttle83
Apr 23, 2008 | Televison & Video
Doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Jan 31, 2008 | Samsung DVD-HR734 DVD/HDD Recorder
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
