Getting service error 5600 on an ip1500 canon pixma.
I just put a new ink cartdrige and i keep getting the same error: service error 5600
After adding black ink to my canon pixma ip1500 it stopped printing and gives me error 5600
Service Call Error :>>No print head detected excepting print head replacement (during printing)
Replace the printer as it has failed.
May 16, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Cannot print anything keep getting service error 6000. Have checked connections, ink etc nohing seems to work
This is called "Display Error", First of all, check for paper jam and if so clear them.
Follow the steps below: Press Additional Functions key Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it.
If this doesn't help, then your printer needs service.
Good luck Thanks for using FixYa.
Jun 10, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip1500, bought new ink, cleaned print heads with alcohol, still not printing
Did you buy factory new Canon cartridges or third party cartridges.
If you are using factory new Canon ink, call Canon about their defective ink.
If you are using anything else, want to bet there is no such thing as a warranty.
Don
Feb 27, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
I appear to need to replace the waste ink absorber on my Canon Pixma iP1500. Any help please.
Canon built several models like yours that you can't get an ink absorber for. They are only exchanged during the warranty period where they send you a new printer. After warranty it is considered a throw away printer.
Nov 18, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Keep getting service error 5100. did a deep
An error occurred in the carriage encoder signal. - Carriage unit
Timing **** film Logic board* Carriage motor
Oct 08, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I have cannon pixma ip1500 printer sold in good working condition buyer wants refund saying the waste absorber is full, therefore dont workHELP
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
2,043 people viewed this question
jasbo
jasbo
