Question about Toshiba PDR-3320 Digital Camera
First thing do you charge for this if so i can not do it When looking through the camera lens to take a shot it is bluery and you can not tell what it is. toshiba PDR 3320 digital still camera
  • shelbyking Sep 09, 2009
    no this did not work, if you come up with something else please let me know.
    Thank You
    President:
  • 1,187 Answers
No charge.... FREE!
The eyepiece has no diopter setting.
However, if you press the shutter button "halfway" down (don't press it all the way). the picture will come into focus.
After you focus, then press the shutter button all the way down.
This will work...
Posted on Sep 08, 2009
When I turn it on the lens keeps moving and it tells me to turn it off and back on. I charged the battery
Maybe the lens is blocked.
Try the following:
1. Turn OFF the camera and push softly the lens
2. Turn ON the camera and pull softly the lens
send me a comments if was helpful and give me rate points
Sep 16, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
Jun 04, 2011 | Canon EOS-5D Digital Camera
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
Jan 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
The lens are stuck out and the camera seem like its coming on but doesnt...Its a DSC-W170 Model
Take your camera and carefully look at the lens side of it. Does the lens look slightly out of center. Sort of pointing very slightly the wrong way. If it is you've given the lens a knock while it's been extended and put the complete lens barrel out of alignment. Please don't try what I've seen touted around the Net and bash the camera lens down on a table, this will make the whole thing completely unusable. The camera needs stripping down completely and the lens either realigned or worse, completely replaced.
The other problem it could be is a piece of grit or sand jammed between the lens elements or the lens and the camera body. Again a strip down job to free the jam.
Just make sure the batteries are at full charge and in good condition if they are getting a bit old try a brand new set of High quality alkalines and see if things start moving then. Quite often the camera may switch on but simply doesn't have enough power to drive the lens. Try the batteries first, you could save a packet.
Apr 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
When I turn on the camera the lens keeps going in and out and will not take pictures. The battery is completely charged. It tells me to turn off and on again and still does the same thing.
This means the camera is having problems detecting the lens position. This usually occurs right after the camera has been dropped on a hard surface. It CAN happen due to a lens problem without a fall. Definite service required (will need a new lens)
Mar 28, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
MY CAMERA LENS OPEN CLOSE E READY ACSESS NO
so i charged my battery, and same thing happends. Bought a new battery, didnt chatge it fully, but had one charge bar on it and the same thing is going on??????? ANy suggestions
Jan 14, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When i turn on my cybershot, the lens extends and retracts several times, then the screen goes mostly black and a message appears telling me to turn off and back on.
Same thing happened to my camera. I have the same camera. I fixed it though. I know what I'm about to say sounds idiotic, but bare with me. If you turn the power to the camera on, and catch. or grab the lens when it has fully extended and don't let it retract. Wait until it has stopped wanting to move than the fun part happends. Atleast for my camera it felt as if something got in around the lens. so if you twist the lens you will have about a fraction of play to twist the lens back and forth. This fixed mine. Try this with yours. But don't be too rough. gentle. I mean. these camera's are expensive afterall aha =)
Dec 20, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cyber-shot dsc-n1 screen gone black
If you can, take a good look at your lens. In this case, this is an actual lens of a DSC-N1 in which you can see lines in it. This is not a shutter, it's physically cracked.
This assembly is fairly easy to replace. However, I don't know what Sony would charge for the lens. This is why you can take pictures but everything comes out black. Not sure exactly what this piece does but I do know it has something to do with the transmission of light that goes through the lens.
If this is your case, for sure you will need to replace the lens assembly. Another thing you can try for those of you who do not have a broken lens, is put a flashlight right up against the lens and see if the display shows any light. In any case, this is your problem.
Aug 31, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Problem*cybershot DSC-S40
You have a jammed lens error the lens has to be repaired or replaced. You dont have to drop the camera for this to occur it can happen when ever the camera is in your pocket or purse. it accidently gets turned on and when the lens is coming out it is obstructed and strips the little plactic gears in the lens.
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony-cyber-shot dsc-w50
Lens unit is faulty, may have had sand or damage at some time, focus assembly inside the lens is not focussing
Sep 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Toshiba PDR-3320 Digital Camera Logo
21 people viewed this question
Top Toshiba Cameras Experts
john milligan
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
