Question about SMC ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub (SKU2218600910)
ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub adapter
Maybe the easiest question of the day - I picked up an ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub but don't have an adapter. I can see it needs 3.3V, but how many milliamps does it use?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Only thing you need to get a 3.3v adapter. your hub will work when to turn it on.
i guess it uses 5mA.
Posted on Jan 04, 2008
  • jacobspj Nov 25, 2010
    I have a eight port Asound switch and the supplied wall wart is rated at 3.3 V 1.0 A, haven't checked the actual current drain.
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
How to connect switch hub
Plug an Ethernet cable into the back of the hub.
Connect the other end into the back of the switch.
Power on the switch by connecting its AC adapter. It should integrate into your network in less than a minute.
Jul 28, 2012 | D-Link DES-1024D 24-Port Ethernet Switch...
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
My lan adapter doesnt get the link to my cable modem how do i fix that it works when it wants to work :(
Sounds like perhaps you are switching between the Wii and your PC. Cable modems often need to be cycled (powered off for 30 seconds or so then turned back on) if the Ethernet connection is changed from one device to another. This is especially true of cable modems with a single Ethernet port. Easiest way to fix it is to add a hub or router but if you are doing that you might as well switch over to wireless connectivity.
Mar 09, 2010 | Nintendo Wii Console
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Tutorials On How to configure a D-Link DES-1008D Ethernet Swich
There really isn't much to setting up an ethernet switch hub. Plug a network cable into your router LAN connection and into port 1 or uplink port of your switch. All other computers will attach to ports 2 to 8. If you have an Uplink port and port 1, they usually can only be used singlely. That is to say use either the Uplink or port 1 Using both disables the switch hub.
Jun 01, 2009 | D-Link Computers & Internet
Hub not working properly
Maybe your hub port is not using auto sense port.
Aug 30, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
SMC ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub (SKU2218600910) Logo
277 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
