Question about Kenmore 22422 Top Load Washer
Kenmore washer leaking
My washer leaked everywhere when i tried to wash my comforter... it's brand new, is it broken? how can i fix this?
    Problem Solver:
  • 9 Answers
It's also possible that your comforter displaced so much water that the cycle you selected simply overfilled the tub. Many household washers do not have enough capacity for full/queen king washers. Run a normal cycle with a normal-size load, see if the same thing happens.
Posted on Sep 20, 2009
You probably have a bad pump. I am on my 3rd one
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washing machine - 7 years old - is leaking grease under the front right side of it. What could be the cause of this?
The only part that has gease is the gearcase. It is a sealed system and you can not fix it,you need a new gearcase. You should just replace the entire washer. Sorry
Jun 11, 2011 | Kenmore 24032\24036 Top Load Washer
Brand new Whirlpool Oasis leaking all over floor
Take the back off & make sure the out let hose is still on your pump.
Dec 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Gearcase is leaking oil
What brand??? Whirlpool ,kenmores leak through the front shaft by coulpling. It will still run with low oil, it may get oil on clutch wich can make it slow spin.
Ge's old and new leak oil and can run for a long time with no oil. They will get loud and scize up after awile. Old maytags leak and keep on running. New ones drop dead.
Run yours till it dies, replace the trans with a new one or buy a new washer. There is no fix for any leaks, just replace transmission or washer.
Nov 22, 2009 | Washing Machines
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
THE LEAK IS UNDER WASHING MACHINE,THE BOTTOM, IN THE FRONT ABOVE THIS MOTOR THING.
Leaking water pump, replace pump.(The cabinet has to come off to do this,if you are not comfortable doing this call a repairman).Price will be probably about 90. total
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 washing machine leaking
Your going to have to take the cabinet off to get a better look at where its coming from. I can walk you thorugh it if you want. Your best to enter a live chaf for this. Thanks Dave
Dec 18, 2008 | Kenmore 22422 Top Load Washer
Leaking Washing machine
I would recommend you inspect the washer with the exterior cover removed, so you can actually see where the leak may be coming from. The following link explains how to replace a drain pump on a Kenmore. I submit this to you, because it not only explains how to remove the exterior case of the washer, but in the event that the pump is leaking, it gives you the necessary steps required to install a new one. The pumps are sealed units and not servicebale. If they leak, they need to be replaced:
http://www.fixya.com/support/r397094-replacing_water_pump
When you remove the exterior case, the washer will not operate without the lid switch by-passed. You will need to do this in order to fill the wash tub to see where the leak may be coming from. To by-pass the switch, you will need to unplug the washer and jumper the two black wires together at the lid switch connector on the timer. Use aligator clips on the connector pins to do this. With the lid switch by-passed, you can plug the washer back in and start a cycle.
Look for signs of leaking around the drain pump (located in the front under the wash tub) and all hoses. Also inspect the entire perimeter of the wash tub for any possible leaks. Generally, if you have a leak in the front of the washer, its a drain pump or drain hose connection. If you have a leak under the tub you may have a worn tub seal or cracked tub.
I hope you find this information helpful. Hopefully, you will not need any repair parts. If you have any questions, please let me know.
PS Use caution when operating the washer with the case removed. There are exposed electrical components and moving parts.
Sep 02, 2008 | Kenmore Washing Machines
Kenmore Clothes Washer leakes when filling,it's a top loader.
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Jan 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
