Question about Samsung ML 2010 Laser Printer
Pc sends files to print but never prints. When I try to troubleshoot, the troubleshoot page prompts me to connect the printer, but its already connected. I've tried reinstalling the driver but that doesn't help either. Thanks for any suggestions.
Printer is paused wont restart
it may be that you have a corrupt file in the print queue, a quick fix is possible - switch the power socket OFF, disconnect the PC/Network connections.
power on the printer, it should have had time to clear the memory now, see if the machine is able to print a menu page or config sheet ( open menu enter the information menu- print config sheet:)
if the printeris able to do thiswith no network connections you have eliminated the printer from the problem. next switch on and log into your PC, still disconnected from printer, open print queue and delete all documents from the queue ( your not deleting the files ( just the print requests)) once this is done then reconnect the printer and send first a windows test page ( confirm working connections first ) then attempt to print the failed file - if it fails in the same manner - the file was your problem.
Mar 16, 2014 | HP OfficeJet V40xi InkJet Printer
Tip
Unable to Print on HP Printer
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click ->> HP Print and Scan Doctor to download the Utility and save on Desktop location
Run the HP Print and Scan Doctor file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
* Please rate this solution with Thumbs up and comment to help us improve providing support
on Jun 15, 2010 | Office Equipment & Supplies
I have two computers on my network, an iMac and a PC running Windoew 7. I recently purchased the Lexmark Pro901 and installed it on the network. It(the Lexmark Pro901) seems to connect fine to the network...
It could be a software issue. Try to uninstall the existing Lexmark Pro901 driver from your desktop pc by going to Start menu -> Programs -> Lexmark -> Pro900 Series -> Uninstall Lexmark Pro900 Series. Reboot pc when prompted.
Now, check your Windows 7 if it's running on 32-bit or 64-bit by going to the Start menu -> right-click on Computer -> Properties. Take note of the System Type.
To reinstall, download the Lexmark Pro900 Series driver using the links below: - Lexmark Pro901 driver for Windows 7 32-bit - Lexmark Pro901 driver for Windows 7 64-bit
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
Cannot print, i've already change the ink, black and colored.
Check all cables to and from the computer. Also check that the electrical cable is connected to the wall outlet. Be sure that all cables are securely connected and in the right locations and turn the printer on.
Step 2Try to print a test page. Click "Start", "Control Panel" and "Printers". Right click the printer. On the "General" tab click "Print a Test Page". Click "OK" if the printer prints the test page correctly. If not, follow the onscreen directions for trouble shooting.
Step 3Open Notepad and type some text into the window. Select "File" and "Print". Select the printer that you are trying to print to and print. If it prints, copy and paste the text into program is giving you problems. Try to print again, if again it doesn't print, then a corrupt font may be the problem. Reinstall the font.
Aug 17, 2010 | Office Equipment & Supplies
Printer will not accept the paper no matter what i do. i need to know how to take the printer apart. its a lexmark x85 all in one.
Please, do not take anything apart just yet.
Are you saying that regardless of where you insert the paper, no paper is fed into the printer when a print job is sent to the printer?
If you are, then you need to install the paper in one location, then make sure your driver properties is set for that location. Once that is done, then you need to go to page setup in the application you are using and make sure you are sending the print job to the same paper source.
Also, try using the printer all alone. Don't connect it to the PC. Go into the maintenance menus and print either a test page or a demo page.
If all else fails, do a "Print to file" from the driver. Then when prompted, name the file "papfeed". Send the job to janddgasrepair@verizon.net and I'll see if I can read the file and tell where it is expecting the paper to come from (no charge)
Don
Jun 10, 2009 | Lexmark C533DN InkJet Printer
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing Acrobat 9 pdf file to the Imagerunner 7200
In acrobat go file, print and press advanced. Check print as image. Print the job again and see if you get different results. This does the image processing on the PC. Your document may have a postscript error in it and your device may be set not to print PS errors.
What driver language and version are you using?
Try updating your driver to the newest version, get device status.
You may also wish to try PCL printing for that file. (as a workaround)
Do other files have the same problem? What about when sent to another printer entirely?
Mar 05, 2009 | Canon imageRUNNER 7200 Copier
Printing Problem
You can print the Coniguration page and demos?
If so, somehow you may the settings to the printer wrong.
If you select , file, then print, see that the proper printer is selected.
If you can print those other pages, the printer and connection is fine. There is some setting not sending the print job from the applications.
Really sounds like the printer has be deselected at the default printer
Dec 07, 2007 | HP Color LaserJet 2600n Printer
Samsung ML 2010 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
