Question about Yamaha HTR-5890 Receiver
Yamaha HTR-5890 not powering up
My HTR-5890 just does not power up. When I pust the power button there is no clicks except the click from the switch. I checked the fuse and incoming voltages to the transformer and they are all good. The rest is very hard to get to. I was wondering if anyone can help me out with a service manual. Appreciate your help. Thanks Neeraj
    Problem Solver:
  • 14 Answers
Power supply is burned out. surge or spike got it, replace power supply unit.
Posted on Sep 08, 2009
Htr-3064 reset power on
I had a Power surge in Brisbane this week and found my YAMAHA HTR-3064 AV receiver unresponsive. Thanks to the Squish22's post, I tried the above approach, which is also listed for another Yamaha model (RX-V667) Unfortunately nothing happened. Another post suggested holding the 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) This also did not work.
I thought I'd try pressing all 3 buttons and powering up, which worked a treat. so here's exactly what I did:
Yamaha HTR-3064 - Protection mode reset:
  1. Remove the Power cord form mains power and wait 10 seconds.
  2. Plug cord in and turn on wall socket power.
  3. While holding down "info", "straight" and "tone control" buttons, press "main zone" power button. I got a click and it was good to go from there.
I had all of my speakers unplugged at the time and tested off the headphone jack before plugging all the cables back in again. Not sure if I needed to unplug everything, but I was about to dismantle and look for a fuse when I tried this method.
Saved me a new system / service fee. Hope it helps you too.
Thanks Squish22 and DILLIGAF for the head-start!
Jan 08, 2014 | Yamaha HTR-3064BL 5.1 Channel A/V Digital...
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
No Power
in your power board near the back of transformer you have a backup power source of 5volts. that is for the cpu and the power relay swicth. can you check if you have that 5volts present. What i can see only in your unit is a major brekadown of your main amp section, all power transistros must be busted/shorted, and no chance even for a click on the relay. that is also feature of the protection. you wont be able to get the unit started even for a while. the fuses for yamaha do not normally blow and very often only your protection circuits enables. but in your case it is a very bad output stage now that you dont even get the display on to see the trouble in the built in diagnosis.
May 09, 2008 | Yamaha HTR-5890 Receiver
Remote Prog.Problem
choose source dtv or phono to put in your tv code and then the tv power button will work as well as the tv volume button if you use that.
Jun 05, 2007 | Yamaha HTR-5890 Receiver
Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Nov 26, 2005 | Yamaha HTR-5150
Yamaha HTR-5890 Receiver Logo
639 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
