Question about Mitel Computers & Internet
Our Mitel system IP phones crash / reboot, usuysally
Our Mitel system IP phones crash / reboot, usually during a conversation about once per week. It almost always happens during a phone call one phone at a time.
  • 1 more comment
  • Roger Lawrence May 11, 2010
    Probably a network issue as the Mitel system will send heartbeats to the phones, if it misses 3 beats consecutively the phones will reboot. If you have access to the mitel check the logs.
  • ynotphone
    ynotphone May 11, 2010
    I just re-read your issue...
    -> Are the phones that you are using IP, Digital, or analog?
    -> You stated that the phones are going down one by one, and not the whole system all at once?
    -> Are these phones (if digital or analog) on a pernode?
    -> what software level are you running?
  • ynotphone
    -> What type of system is it?
    -> Is it a 200 ICP or 3300 ICP?
    -> There are logs in both systems that can at least get you started in the right direction.
    -> Is it the phone system that reboots or is it the switch?
    -> What do the phones do when this reboot happens?
    -> What is the Mitel system doing, is there red lights flashing on the system?
    -> Your System reboots once a week, is it the same time and same day... maybe the system reboot has been scheduled for a reboot at that time every week?
  • 7 Answers
SOURCE: Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Posted on Feb 13, 2008
  • 112 Answers
SOURCE: How do you do a factory reset on the Mitel 5220 IP Phone ?
To Restore Factory Default Settings:
1. Press both Up and Down Arrow keys simultaneously while powering up the
phone. NETWORK SETTINGS? appears
2. Press NO until TOOLS & FEATURES appears and then press YES.
3. Press NO until RESTORE DEFAULTS? appears and then press YES.
4. Press CONFIRM. The phone resets with default settings.
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: Is there a mute option while I am on a call?
The mute button is the top right button, it's a clear colored button. When it's lit and orange it's muted.
Posted on Feb 10, 2009
  • 3 Answers
SOURCE: mitel 5220 ip phone locked out ICP 10.0.0.135
Locked out generally means the phone is off the hook and there is no live call. Just press the X or cancel key, or pick up and hang up the phone.
Posted on Jun 24, 2009
  • 6 Answers
Make sure that it is a Dual Mode 5220. If it is you can use it as a SIP extension. It wiill say it on the back of the Mitel phone next to the 5220.
If it is a dual mode phone you can purchase a sip trunk from a provider and then would be able to use the phone.
When you boot up the phone hold the blue super key while the phone boots, hit the no softkey till you get to phone mode. Hit yes it will allow you to change the phone from minet to sip. This should get you started in the right direction.
Posted on Sep 09, 2009
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
Mitel phone only operating in 1 direction
Does the phone have a router/firewall/Layer3 data switch between the phone and the controller? If yes I suspect you have blocked UDP IP ports. Here is a wiki on TCP and UDP ports. http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbersThe ports you need open to the controller are specific to your system model. The 5312 phone works on different controllers. Please list the controller type you have. Good Luck.
Mar 27, 2013 | Mitel 5312 IP Phone
One way conversation on mitel phone on LAN network
What model of Mitel controller do you have? The 5312 works on several different controllers. Sounds like you have UDP ports blocked on you IP network. Please list your controller type and if you have a firewall/router/or layer 3 switching on your data switch.
How do I reboot my mitel 5212 ip phone
Try unplugging the phone line on the base of the phone and replugging it.
Sep 19, 2012 | Mitel 5212 IP Phone
How do you reprogram mitel
You need a program called mitel db programming.
You will need to know the system IP address and the usernam and password.
Once on you can reprogramme any extension, as well as many other things.
Apr 17, 2012 | Mitel 5220 IP Phone
Mitel Phones throughout the property are trying to get re-booted and all that is displayed is an IP address on line one then "Downloading....60" on line two. After this downloading process gets...
The unfortunate thing here is there is a network disruption caused by the network not set up properly to support VoIP or a problem on the network.
The file it's trying to pull from the phone system is very small, and it uses TFTP. If there's a disruption in the download, it will cause the set to reboot.
You need to contact your system admin or your telephone system vendor and your network admin/vendor to have it resolved.
May 24, 2011 | Mitel 5212 IP Phone
How do i configure the voicemail on my mitel 5330 ip phone?
Either your on-Site system administrator, or your vendor will have to make the change. This is a system wide setting, not just your phone.
Once the mailbox is set up in the system, dial the access code and the password (default is 1111). Follow the prompts... you are not complete until the guide tells you are.
Good Luck,
Mark
Feb 08, 2011 | Mitel 5330 IP Phone
Employee left and we need to reset the password for voice mail on the mitel 5207 ip phone
You will need to do this from within the Voicemail system. This is usually done by the site admin or your phone system vendor.
Good luck,
Mark
Feb 05, 2011 | Mitel 5207 IP Phone
On the 5330 i have a Discovery option 128 missing message. There is not a dialtone on the phone, how do I make the phone operational?
I had this problem as well. This is a configuration that needs to be added to your DHCP server to enable the mitel system to obtain an iP address. If you reboot the phone and hold the down arrow it should bring you to a screen you can manually enter the IP address of the network you are useing.
Jan 26, 2011 | Mitel 5220 IP Phone
HOW MANY CALLS PER MINUTE YOU CAN GET ON MITEL
It really depends on how many trunks you have, how many people you have and how efficient they are. It also depends on the system you have, not necessarily the phone the users are using.
You should contact your vendor for helping set up the most efficient method of setting up call handling.
Aug 25, 2010 | Mitel 5220 IP Phone
Computers & Internet Logo
272 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
