Question about Dell Latitude D505 Notebook
Display goes off after few minutes of working. But the system is on. System has to be switched off by pressing the on/off button.Same problem continues if you switch on the button after some time. A lock glows in one of the warning lights by the side of the on/off button. A solution to this problem is greatly appreciated.
    Novelist:
  • 110 Answers
Before I can give you a solution you need to troubleshoot further. If you can, connect your Laptop to an external monitor. Use the PC as normal, if it continues to work with no issues on the external monitor then you will need a new LCD screen.
Is the display off.... or is it just really really dim?? If it is dim then the backlight on your LCD screen is bad, and you will need to purchase a new LCD screen.
Does this only happen in Windows? Can you go into the BIOS and leave it for a while and see if it still does it. If it only does it when you are in Windows then it is a software issue, probably a driver. If it occurs outside of Windows OS then it is a Hardware issue.
What does this mean... "Same problem continues if you switch on the button after some time." ?????? what are you trying to say? That you have to let it cool down before you can turn it back on to get video... if you have to let it sit for a while before it will work again, then your PC is OVER-HEATING. Which is probably fixed by cleaning out all the dust from the heat-sink and fan. Hopefully you didn't fry your video card.
Further steps are needed to diagnose your issue.
Posted on Sep 08, 2009
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How do you set the clock on a 2004 gmc ykon
According with the Owners Manual:
* Setting the Time for Radios without Radio Data Systems (RDS)
Press and hold the HR or MIN arrow for two seconds. Then press HR until the correct hour appears on the display. Press and hold MIN until the correct minute appears on the display. The time may be set with the ignition on or off.
* Setting the Time for Radios with Radio Data Systems (RDS)
Your radio may have a button marked with an H or HR to represent hours and an M or MN to represent minutes.
Press and hold the hour button until the correct hour appears on the display. Press and hold the minute button until the correct minute appears on the display. The time may be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the hour and minute buttons at the same time until RDS TIME appears on the display. To accept this time, press and hold the hour and minute buttons, at the same time, for another 2 seconds. If the time is not available from the station, NO UPDAT will appear on the display.
RDS time is broadcast once a minute. Once you have tuned to an RDS broadcast station, it may take a few minutes for your time to update.
Hope this helps.
Mar 29, 2011 | GMC Yukon Cars & Trucks
Need to change the clock in my jimmy and dont know how,,theres no manuel
I found this solution already was answered by: chavezemail
Rank: Wiz gmc.gif Expert
Rating: 87%, 24 votes
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
Jul 12, 2010 | 2000 GMC Jimmy
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [–DEMO] until “NO DEMO” is
displayed.
Each time you press and hold the button:
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
How to set clock in 2000 GMC JIMMY
MN Buttons
time-set mode.
SET Button
Nov 13, 2009 | Car Audio & Video
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
My DELL laptop display goes off after few minutes of working. But the system remains working and you can switch off the system by pressing the off button. But when you on the system the display appears but...
read up on your manual on how to shut off the monitor (so that you can use an external one). it may be toggling on. other options are to make sure you have the newest driver and also to shut off the screen saver function. does this happen when you are plugged into the mains or just when you use battery ?
robert
Sep 02, 2009 | Dell Latitude D505 Notebook
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
and MN Buttons
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Nov 05, 2008 | HP PhotoSmart 1215 InkJet Printer
Dell Latitude D505 Notebook Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
