I have a choice of two different carrier ac models for home installation - 24aca336A003 and 24acb336A003. can you tell me the difference between the two?
    Scholar:
  • 48 Answers
I believe the aca uses R-22 refrigerant
the acb definitely uses R-410a refrigerant
otherwise the units are same specs.
Posted on Sep 08, 2009
When my phone rings, it states "roaming," even though I'm not traveling. Any ideas why?
It could be that your carrier's signal is being "overpowered" by a different compatible carrier's signal. It could also be that your phone needs an update to your carrier's local network. It would be helpful to know the model of your phone and the carrier you subscribe to for a more pinpointed answer.
Sep 08, 2017 | Cell Phones
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 30, 2017 | Bryant Heating & Cooling
Plugs on Carrier yc273d air conditioner
You probably have a 230 volt AC that uses a different plug. If you insist on using unit there you will need an electrician to run the correct wiring and install the correct female for your unit to operate.
Jul 13, 2015 | Carrier Heating & Cooling
AC duct temp range.
you need to take the temp of whats coming out of the plenum and the temp at the return and subtract them and you should have a difference of 17-20 degrees, that will tell if you are cooling properly,
Aug 03, 2014 | Carrier Heating & Cooling
Why same different AC companies has the same model number
There are a number of manufacturers that make equipment for many different brands and just have different paint schemes. Rheem and Rudd...one is brown, the other green. Carrier, Day and Night, Payne are the same units with subtle differences. Kenmore, Whirpool, and several others are manufactured by the Heil Quaker Corporation that became ICP a few years back. The list goes on and on.
As a matter of fact, some have the different badges in a baggie delivered in the box so the appropriate one can be place on the unit when installed.
May 14, 2014 | Comfortmaker C4A348GKD 4 Ton 14 SEER AC
Carrier 48NMX042 IFM wont stop, condenser fan motor and compressor wont run
Ok first thing is it sounds like a wiring problem. So first step is to make sure the thermostat is properly connected. Which... the main thing here is there needs to be 24v dc power coming from your control board (transformer) going to the thermostat..generally that is the red wire. All the thermostat does is connect that "red" wire (power) to one of the other wires to complete a circuit. So make sure you have 24 volts... (generally about .5amps) . if you have power than switch thermostat to fan only should energize the green wire only. then switch to ac and move temp low enough that the ac should turn on and that should energize the yellow wire. for sure one of those wires is incorrect now or the fan wouldn't be on OR THE THERMOSTAT IS NOT CONNECTING THEM AND IT IS BAD. Now about the compressor and fan.... those same wires run out to the compressor unit... ok the yellow for ac.. greeen does not go to compressor unit that is for fan only (vent).. red carries the same 24 volts... one difference here is that most carrier units only have the one transformer....so you run the red wire is the +pos 24 volt..and then a "common " wire is needed which is the Ground or neg... that wire on a carrier is brown usually but could be different depending installer. The orange wire goes to the pump reversing valve it is always energized when on ac mode...when heater is on in the winter it is heat pump and is not energized so just connect the orange and yellow together... tell me more specifics if this doesn't help and i'm sure I can help you... thanks Chuck
Jun 22, 2012 | Carrier Heating & Cooling
I have carrier heat and air model numbers 58sx and 38tg what sizes are these
You need more information to get the size. The Carrier 58sx series includes 5 different models: 40 - 41000 BTUH, 60 - 61000 BTUH, 80 - 81000BTUH, 100 - 102000 BTUH, 120 - 122000BTUH. An installation guide for the 58sx is available here: http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/58sx-14si.pdf . The Carrier 38tg has 6 different sizes (020 - 20,000BTUH through 050 - 50,000BTUH). The other sizes are 025, 030, 035, 040 and the capacity is that number multiplied by 1000.)
To determine your model's capacity, look at the full product number. The first three numbers after the 58sx or 38tg will indicate the nominal capacity.
I hope this helps.
Oct 25, 2011 | Heating & Cooling
I go to the internet on my phone i write google.com and it says (connection failed) i dont know why please help me
Check the Settings for Internet from your phone's Menu.
You did not provide a make or model phone you have, so I cannot tellyou specifically, but the phone needs to be configured to your Internet account.
First, you need an Internet account for your phone. Are you paying for Internet access to your cell company? Its not free, it costs extra on top of your voice line charge.
Have you installed the IP adress for your Internet account into your phone?
Your IP adress must be correct, most phones will auto- recieve them, but you must tell it to do so
Once again, without your make and model, I cannot give you exact menu choices, but look under Settings, then look for Internet settings, then look for IP adress info, and choose the Auto-fill feature.
Your ISP might have you give a password once you've connected. Most carriers use the 10 digit cell number as default password. Some use all zeros, some none at all.
In any case, if you have ever set up an Internet account on a home computer, then you've seen the procedure. Your cellphone Internet Setup isn't much different.
To summarize:
You do need an active Wireless Internet account from any ISP
You need the Gateway IP address, your phones IP address, and the subnet mask
Password, if any ( If forgotten, call your carrier)
Feb 01, 2011 | Cell Phones
Driver problem
Best choice is installing drivers from HP website.
Here is the download page for C700, select proper model, different models may have different audio, video and ethernet drivers. On next step you will be asked to select OS (windows version), then you can download drivers for all devices listed.
If some model does not have specific drivers, try generic c700 model download.
Additionally here is the user manual
Compaq Presario C700 Notebook PC
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Heating & Cooling Logo
177 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
