Question about Lexmark X6675 Pro Colour Wireless Multifunction Printer
Lexmark sucks I could scan, once in those halcyon days now past. The scanner will show a "Downloading Application List" message, I assume it just doesn't say that it failed but it never seems to download. Noticed that lexmark printers have been having this same problem for several generations, but apparently the solutions that worked for the old ones don't work anymore. I have pressed the button on the printer, run it through the productivity studio (which immediately shows a sort of error message that doesn't actually admit to being an error), tested it as printer (it works that way), unplugged the printer and waited and plugged it back in, reinstalled the drivers on my computer, and am currently waiting for someone to answer my questions on the livechat. I have been waiting for an hour now. Glad I bought one on my own before I ordered them for my company. Anyone know an uncommon workaround for this, because I am kind of stuck with mine for now. Thanks.
SOURCE: Lexmark X83 "Unlock Scanner" error
I had this problem and am still getting it regularly
Lexmark support say remove power and usb leads take off loose top and take out papers turn it on its side and shake vigorously!
It works for me.
Best of luck...
Posted on May 04, 2008
  • 684 Answers
SOURCE: scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 25, 2009
mamun97
  • 29 Answers
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
854
Posted on Mar 02, 2009
jafor
  • 7 Answers
SOURCE: lexmark x5470
937
Posted on Mar 03, 2009
  • 175 Answers
SOURCE: "Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Posted on Mar 19, 2010
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P6250 won't scan in Vista64
Disconnect the printer or at least be sure it is turned
off. I'd do both and reinstall the CD software program
that came with the printer.
When the software program asks you to
connect the printer to the USB port, do so and it
should again work properly.
Hope this is of some help. Bud
Jul 12, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Scanner
Reinstall the software/drivers and try again.
May 23, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X6675 Pro Colour Wireless Multifunction Printer Logo
170 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
