Question about Garmin Quest GPS Receiver
I have a Garmin Quest that will not transfer maps from my PC.
Not enough space to send map to Quest2
Hi I have a Garmin Quest 2 and I am trying to load full european maps , but I get the error not enough space to load selected area, please select a different region, I have deleted my track points and reset teh device but still get the same error.
thanks Mark
Posted on Jun 13, 2010
  • 24 Answers
I would guess the GPS is not communicating with the PC for some reason.
Using the MapSource or City Select software, can the software read the GPS. At the top of the screen is a small GPS unit icon. When you cursor over it (do not click), a small flag should come up that says, "Send to Unit" or "Receive from Unit". If your Quest is connected to your PC, then it should immediately recognize the GPS and give you a serial number. If this did not happen, then there is a problem either with the USB cable, USB port on your PC, or the USB port on the GPS. If the GPS has ever been opened up, it is possible the two halves were not reseated tightly enough. With a small phillips head screwdriver, tighten the six screws holding the unit together as you squeeze the front and back together with the other hand. Another possibility, Garmin has a system where only two GPS units can receive mapping data for any of their mapsets, so your software, maybe for some reason locked out of that. It may still be able to manipulate waypoint data, etc. I don't know. If the two halves of the unit are as tight as they will go, don't try to overtighten the six screws. If you feel comfortable around circuit boards inside electronic devices, you can take the unit apart by removing the six screws. Be VERY careful on the two screws on the right hand side of the back (GPS facing down, antenna hinge away from you). These hold an endcap which holds the antenna in place. There is a spring loaded plunger inside here and if you are not careful, the spring, under tension, will pop out and is easy to lose. Be VERY careful separating the two parts of the case as there are wires connecting them. Once inside, if you look on the circuit board, you will see 4 or 5 circuit board "pads" in about the same area as the USB connector on the back half of the unit. Using a q-tip and isopropyl alcohol, gently clean these pads. On the back side of the unit, you will see a series of spring type contacts that would mate up with these circuit pads. Gently clean them also with the q-tip and alcohol. Reassemble the unit being careful to not kink or crimp the rubber gasket that goes in between the two parts of the gps case. Insert the 6 phillips screws and gradually tighten them down. Criss-cross the unit and if necessary, squeeze the unit together while tightening the screws to insure an even pressure on the gasket and the gps case. This will be all that you can do if the problem is dirty contacts on the USB connector. If it is a software issue, you will need to contact Garmin.
Posted on Jan 26, 2010
Hi I have a Garmin eTrex Venture and have downloaded maps from Mapsource. When I turn on the GPS and go to the map page, no map appears on the screen.
Did you download the maps via your PC into Mapsource and then transfer them to the Venture? You have to unlock the maps on your PC with the code which is specific to your unit.
Sep 26, 2009 | Garmin eTrex Venture GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Garmin Quest Coordinates
Menu/ Map Setup/ Layout/ Orientation,  choose 'North up'. To return to normal choose 'Auto'
Aug 19, 2008 | Garmin Quest GPS Receiver
Unlock codes
You will need to contact Garmin to obtain unlock codes for the maps.
Mar 16, 2008 | Garmin Quest GPS Receiver
Can't get maps to unlock
Call Garmin support @ 1-800-800-1020
Feb 09, 2008 | Garmin Quest GPS Receiver
Garmin Quest unlocking maps
i BOUGHT A QUEST ON E-BAY, WHEN I TURN IT ON AT THE BOTTOM OF THE SCREEN, " CAN NOT UNLOCK MAPS" HOW CAN i UNLOCK THIS UNIT SO I CAN PROGRAM IN CITIES AND STATES.......
Feb 06, 2008 | Garmin Quest GPS Receiver
Downloading maps to my gps
you transfer them into the SD card
Oct 31, 2007 | Garmin eTrex Vista Cx GPS Receiver
Uploaded Map Update 2008 City Navigator North American NT now maps locked
I held on the phone with Garmin for about 2 hours, but they fixed my unit, PATIENCE!
Oct 19, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin Quest GPS Receiver Logo
279 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
