Question about Lexmark X8350 All-in-One Plus Photo with USB Cable Printer
Lexmark X83 - The printer has an A06 error, states "paper jam"
There is no paper jammed in the printer. Please advise?
2 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: x83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
Receiving an error 234 jam on the Lexmark E360d printer but there is no paper jam. I have turned off the printer and it still will not work. Please advise asap.
You may be having a problem with your paper sensors. If your printer is covered under warranty contact Lexmark and have the issue covered under warranty. If not you may need to contact your local Lexmark dealer.
Jun 07, 2010 | Lexmark E360d Laser Printer
Printer thinks there is a paper jam, but there is no paper jam. Can you help? Paper will not feed.
Hello sir; First, check carefully go through entire paper path make sure there have nothing stuck over there, then check the both end of the cross bar ( carriage steel shaft ) find anything removed it.
Oct 11, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Cannot print anything at all.
Try to add some paper so that the sensor will detect the paper.Try to cheeck the sensor as well.
May 19, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x2350 will not work Machine states ''paper blockage''when there is no paper in and refuses to take paper there is somepaper in Please advise if you can.K Milson
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Dec 03, 2008 | Lexmark Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Won't move paper
Never remove paperjams from the back. this will damage the feed roller. get sandpaper (1 layer) insert it in tray start print and whatever you do DO NOT let go of the sandpaper until the printer is quiet. It should work.
Nov 03, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X8350 All-in-One Plus Photo with USB Cable Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
