Question about Hitachi 42HDS69 42 in. Plasma Television
My 42 inch Hitachi UltraVision has a green Bar just past center
I have been experiencing this green bar intermitently on the right side just past center, measure about 3". In some cases in turns black and flickers, fades, dissappears and re-appears, comes and goes randomly. I power the main switch off over night and this seems to clear up for a week or so ( it hadnt happened for over 3 months and recently re-appeared. Any advice out there? Before i take this to a repair shop can anyone help me?
3 Suggested Answers
Big Hev
  • 64 Answers
SOURCE: Vertical Green Bar 3" wide on the right side of my 42" plasma
My thought is that it is an Intergrated Circuit (IC). But it has been brought to my attention that it may be as simple as adding a "ground adapter" to the plug of the TV. If after you try changing out the ground adapter and it doesn't work, try "power cycling" your TV. (unpluging it... Waiting 30 seconds, then plug it back in.) If that fails, contact Hitachi so they can recommend an authorized service center in your area. Hope this helps. Good luck, KMarshall!
Posted on May 25, 2009
  • 8457 Answers
SOURCE: hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Posted on May 23, 2011
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Hitachi ultravision 50v500 ghosting
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=support_contact/remote_ir_codes/index.html&level=2&section=support_contact&parent=remote_ir_codes&nav=left&path=jsp/hitachi/forhome/ubcg/&nId=iD
Mar 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
May 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Color bar
Sounds like the TV is defective, if I were you I would take it back. There probably isn't much you can do on your own to fix it.
Jan 08, 2009 | Televison & Video
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Hitachi 42HDS69 42 in. Plasma Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
