Question about Nokia E71 Smartphone
Hi, my email has an error and not receiving any email. it states 'authentication failed - mobile nr and password not accepted by server.'
How do I change my wife's email user name?
Here is Microsoft forum on the error code
Windows mail error code 0x800ccc90
Cause for this error is generally The client is trying to use Secure Password Authentication and it is not enabled on the Exchange Server computer. To verify what form of authentication the Outlook Express client is using, in Outlook Express, on the Tools menu, click Accounts, and click the Server tab for the account that failed.
Also when your adding the 19 to the email it is creating a whole new email. So if you created the new email. then please refer to this link
POP3 Outlook Express error 0x8000CCC18 and Exchange Server
Aug 10, 2014 | Microsoft Outlook Express
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
Sep 21, 2008 | Computers & Internet
Tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
on Mar 12, 2010 | Microsoft Office Outlook 2007 for PC
I get my gmail mails in my mobile mailbox directly however i am not able to get yahoo mail while setting yahoo mailbox its shows DNS fail please help me if you can
make sure you have the correct settings.
Incoming:
Username: yahoo email without @yahoo.com Password: Your password Type: POP3 Server: pop.mail.yahoo.com Authentication: SSL
Outgoing:
Require login: Tick SMTP server: smtp.mail.yahoo.com Authentication: SSL/TLS Port: 587/25
Feb 03, 2011 | Cell Phones
Hi my name is pandi.c i configure the mai id but smtp authentication error is occured any pls help me
Hi pandi ci smtp autthentication error occurs if the email id or password you configured is wrong or the smtpserver did not respond. the authentic email id should have the same extn as the smtp server
for example:
if your smtp server is smtp.gmail.com ten the authenticating email id should be xxxx@gmail.com.
the error also comes if the smtp authentication has been enabled. you can disable it and send docs without authtion . contact you sys admin . ok hope this helps u . bye
Narasimha kumar (INDIA)
Jan 19, 2011 | Canon iR 2016i Black and White Copier
Cannot connect to subscriber in China
Typically this error indicates that you are trying to send your Adhost email through Adhost’s mail server when you have not authenticated your email account to send mail. Our mail server authenticates you through your pop account. So when you check your email, our mail server authenticates your pop user and password, captures that IP that you are checking your email from, and adds that IP to our relay list. This list is flushed every 70 minutes. This means, if you try to send email after the relay list has been flushed and before you’ve attempted to check your email, you will receive this error.
How to fix the problem:
Fix #1 - reauthenticate on our server.
Remove any email from your Outbox. If you need to keep the message, you can move it to your 'Drafts' folder.
Click "Send/Receive". This will reauthenticate you.
Try resending the email.
Fix #2 - configure your email client to check for email before sending.
In Outlook, go to "Tools" and select "Email Accounts". Make sure "View or change existing e-mail accounts" is checked. Click Next.
Select your account from the list and click "Change".
Select "More Settings".
Select "Outgoing Server".
Check "My outgoing server (SMTP) requires authentication".
Select "Log on to incoming mail server before sending mail".
Click "OK", then "Next", then "Finish".
This will fix your problem
Or
Call Yahoo! Customer Service
USA: 1-866-562-7219 --- 1-800-318-0631
UK 020 7131 1000
Canada: 1-877-722 3755
Direct Number: 1-408-349-1572
Regards
manish
Mar 20, 2010 | Yahoo Mail
How to set up my gmail account on Motorokr E6
Do the satting given..
Send Setup:
Server: smtp.gmail.com
Port: 587
Email: <my>
Nickname: <my>
Authentication: on
Username, Password, etc: Same as Receive Setup
Use SSL: Yes
Receive Setup:
POP3
Server: pop.gmail.com
Port: 995
User name: <my>
Password: <my>
Keep on Server: checked
Incoming Messages Sizes Limit: 512K
Use SSL: Yes
Mar 10, 2010 | Motorola Mobility MOTOROKR E6
Yahoo email address will not accept my message
Are you using a mail client to send out emails? Outlook maybe? You can enable (check mark) "My server requires authentication" from your outgoing mail server settings in Outlook.
Some mailservers require this to avoid email spamming.
Jun 28, 2009 | Yahoo Mail
Nokia E71 Smartphone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
