Question about Garden
Chain saw stalls after a bout 10 minutes of operation. Will not
Craftsman Chain saw stalls after about 10 minutes of operation twice during operations. FIrst time was able to restart. Now wll not start after 10 minutes.
    Sergeant:
  • 302 Answers
Make sure your gas cap is vented. If it stalls and you open the gas cap and then reclose it and it then starts then you are getting a vacuum lock in your fuel system from not having a faulty gas cap. hope this helps
Posted on Sep 08, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
I have a Craftsman 3.5 hp 16" Electric Chain Saw that I haven't used in year. Are their key steps to clean-it up operationally before I use it or start it?
Kcbriangerli:
I would first clean the saw... especially the chain drive area (remove the cover first and use compressed air if you have a compressor). Check the drive sprocket for excessive wear. Check the power cord for any damage. pull up on the chain at the middle of the bar to ensure the chain is not too loose or too tight (the chain should be able to be pulled up one eighth of an inch... no more. None of the dogs at the inside of the chain should come completely out of the slot in the bar. If the chain is too loose, adjust it by reinstalling the cover, ( When you put the cover on, make sure that the small nib on the chain tensioner fits in the small hole in the bar). loosen the two chain bar retention nuts and adjust the screw at the front of the main body next to the bar. When the adjustment is correct, tighten the chain bar retention nuts and check the chain tension again. If you have a chain sharpener, now would be a dandy time to sharpen your chain.
Jan 20, 2013 | Craftsman 16" Electric Chainsaw Chain Saw...
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
Feb 01, 2010 | McCulloch 10" Electric Pole / Chain Saw
Oar lock recepticals are loose. ? held in place by rivets? ? how to repair
Firmly attach the anchor chain to the TrollAnkle and fully submerge for 10 minutes. If you really have a problem take it to a Husqvarna dealer and resubmit your question with the correct terminology. Lou
Aug 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Brand new Husqvarna 340e chain saw dies after 10 to 20 minutes.
Hi
Find out where is its airating sistem.It equalises the presure between the interior and exterior of the gas tank.Disassembly and clean it.
regards savumihai71
Dec 05, 2008 | Husqvarna Garden
Garden Logo
302 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
