Question about Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
My washer dryer was leaking badly at the bottom. The repairwoman diagnosed the problem as a damaged gasket  on the cleanout at the front bottom of the machine. She ordered a replacement gasket from Malber back in October 2007. It is now Dec. 9, 2007. The gasket has not yet come despite her repeated calls to Malber. She says that the gasket cannot simply be obtained in a hardware store.
Is there some way to get this gasket? Or is there some other way to seal the cleanout?
The water damage from this second floor leakage was extensive. The cleanout seems to me to be poorly designed and invites problems.
Thanks in advance for any suggestions.
  • buddy372 Jan 31, 2008
    My Malber WD1000 is also leaking all over my floor. I just bought a condo and the machine came with it. Please help!!!
    Problem Solver:
  • 13 Answers
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (
Posted on Jan 07, 2008
Malber 1000 started leaking from the bottom. Water is coming from underneath the machine in the area behind the filter area
Usually what I have found is a small hole in the drain hose or coin trap, sometimes mice chew them and sometimes It is an abrasion wear from the balance brick rubbing. pretty easy fix though.
May 06, 2011 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Apr 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Where do i put detergent
Contact Malber USA ( to order a new Manual.
Dec 11, 2007 | Malber WD1000 Front Load Washer/Dryer
Leaking front gasket
Try to call 800-600-8913, they gave couple of number to call
Nov 07, 2007 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
237 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
