Question about Maytag Neptune FAV6800AW Top Load Washer
Only hot water will fill, cold water will not
My maytag neptune front load washer will fill with hot water only but not cold. There is no blockage of the hose and the water source is good and strong.
  • 574 Answers
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Posted on Sep 08, 2009
After a complete cycle the drum fills (slowly) with water leaving clothes soaked.maytag Neptune front loader
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer will not fill up
by "fill up " I take it you have no fill.
If it partialy fills it is the water level switch
If you get hot or cold the hot or cold coil may be faulty
if you get no fill at all- and it spins - it may be timer
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500AWW will not fill from hot water side
check out the hot water tap is on then check out the hot water valve for continuity (poss 27 ohms) then check for blockages in the small inline filter at the valve.
Jan 20, 2008 | Maytag Neptune MAH7500A Front Load Washer
Wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
