Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Light flickers and clicking occurs when you open the door.
We tried to replace the bulb but it did not work.
    Scholar:
  • 48 Answers
Usually this is the switch that operates as you open and close the door. Try snapping the switch a few times. This may make it work for a few days so you can replace it. These are very common switches which pop out by prying gently around the edges of the plastic.
Posted on Sep 08, 2009
Ford taurus tss 2004 map lights work but dome light wont come on
It is possible the bulb in the dome light is burnt out or there is a bad connection @ the bulb. That is at least where you start. you will need to remove the dome light cover & wiggle the bulb while the door is open, or best to have two doors open to remove the possibility of a faulty switch. If it still doesn't flicker or start to work remove the bulb & inspect it to see if the filament is broken. If you can't tell best to replace the bulb & try again.
Please advise if you need more help.
May 29, 2014 | Cars & Trucks
Garage doors work but the light on one of the inside opener keeps flickering, What do I do?
disconnect the power and try to pry the prong in the socket of the light outwords,check the connection in the unit itself
Jun 11, 2011 | liftmaster Chamberlain Garage Door Opener...
The light bulb on my opener is off when it should be on. If I screw the bulb in or out slightly, it turns on and flickers a bit. When the timer times out, the light goes out. If something crosses the...
Unplug the opener and remove the bulb. Use a small screwdriver to pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Model 139.53515SR overhead lights stopped working. Checked bulbs and all connections. All seems O K. What could be the problem? When I tap the unit ,at times the lights will flicker like...
Unplug the openers and remove the bulbs. Using a small screwdriver pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
The small green LED light on garage door motor head out
That little green bulb just flickers when the logic board is receiving a radio signal and is also used to send a code to assist with diagnosis. It does not keep the opener from working. You say the door is 'stuck'. If it is stuck in the open position the trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain to relieve the pressure and the opener should run. When the door is closed locate the 'up limit' on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Then tighten the chain.
Mar 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Refrigerator door light is clicking when door open; light flickers, or does not work at all
check the door switch to see if its working. also check the bulb it may be loose in the socket.
Jan 21, 2009 | Whirlpool GD5SHAX Side by Side...
1/2hp Craftsman Garage door opener light bulb
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
No power to unit
I would first suggest that the door switches and door switch mounts be checked, but one of the problems is almost certainly trouble on the control panel, which we regularly repair nationwide for $39.95 postpaid.
The light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on. Other trouble can occur as well.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement,
disassembly information and info on our repair service at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Nov 17, 2007 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
