Left my microphone home. Can I use the built-in mike on my MacBookPro? As an aside - - Does "support" at MacSpeech really work? I can't get connected to them
  • 4,281 Answers
Yes you can use it but for that you have to install proper sound driver in your mac book.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 08, 2009
I have just purchased a Trust webcam which states it has a 'Built in Microphone' (which can be seen on the face of the product), however it only has a USB lead. How can this record sound?
I don't really know but the mike only lets you to be heard by the other party, it dosn't actually "record" (same as mike on cell phone)
Nov 29, 2013 | Trust Computers & Internet
Retrieve recordings on malfuctioning Philips Voice Tracer 662
Vienna it is, that's built in memory and flash memory also so it may be gone anyways. They are the only one that has the ability to get anything off of it and don't count on it.
Jun 18, 2017 | Audio Players & Recorders
I have a Sony JA3ES it want record in analog inputs.everything else works what would make this quit working.
I'll give you my best guess since I sold my JA3ES and am doing this from memory. Check your analog connector cables are good, be certain you have the input switch set to analog input.
Be certain you are not setting your inputs for the microphone jacks. If you are getting the error message din unlock the recorder is not getting the signal from the analog source.
It is possible to have damaged analog inputs on a used machine, but you have micorphone jacks and might get adaptor cables to hook your analog inputs in through the microphone jacks. Note this machine is old enough the microphones are 2 mono microphones left and right. If you want to use a modern stereo microphone you need an adaptor cable for that too.
If you try the above be careful as the mike jacks are really for mikes not what I mention, but it is a probable go around if your rear analog jacks are damaged for some reason.
Jan 11, 2012 | Sony Audio Players & Recorders
How do i turn my lap top microphone on or do i need to plug one in regards mike
Hi Mike,
The spec say it has a built-in microphone. If you are using Windows, open the sound controller and check that the slider on the microphone is turned at least half-way up. When you open the sound controller (speaker in the systray next to clock), the microphone is normally muted. To test, unmute and tap the microphone or speak into it. Make sure you have the volume turned up on the speakers too.
The dv1000 notebook is equipped with:
  • 1 Type I/II PCMCIA card slot. I store my Media Remote control. (left side)
  • 1 IEEE-1394(Firewire) (right side)
  • 3 Universal Serial Bus (USB 2.0) (Two on the right side and one on the left)
  • 1 Built in 6-in-1 digital media reader (No Compact Flash)(Right Side)
  • 2 headphone-out (front)
  • 1 microphone-in (front)
  • 1 TV-Out (S-video) (right side)
  • 1 RJ-11 (modem) (left side)
  • 1 RJ -45 (LAN) (left side)
  • 1 External VGA monitor port (left side)
  • 1 expansion port for use with HP Expansion Base(sold separately). Available only with Intel Extreme graphics with productivity port (left side)
  • Power jack (in the back)
  • CD/DVD drive (right side)
Jun 01, 2011 | HP Pavilion dv1000 Notebook
Does it have a microphone
No.
I wouldn't reccomend buying a camera with a built in mike. They're usually pretty awful. Far better a separate mike or headset with built in mike.
May 01, 2010 | Ezonics EZCam III Webcam
I am attaching an external microphone and need to mute the internal mic. They both work and it echos. PLease help.
Adding a mike doesn't create echos/feedback. Windows? Version? Right click on speaker icon in lower right and go to recording device mixers, can mute and adjust level of sound sources, also microphone power and pre-amp. Telephones and other devices (laptops) with both input and output will feedback unless the input is "noise cancelling", so you will have to be much more careful with the placement of the external mike compared to using the built in mike.
Oct 14, 2009 | Computers & Internet
Toshiba laptop Microphone Not working or Non-existant?
Click Start/All Programs/Accessories/Sound Recorder. Click Start Recording and talk to your computer in a normal voice. When you finish click Stop Recording. Type in a file name and click save. Open the file and play it. If it works you have a built in mike, otherwise buy yourself an external, which I recommend anyway, because the built in mikes are generally not good enough for voice recognition or VOIP.
Sep 22, 2009 | Toshiba (P000257700) Microphone
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
My fathers built in microphone of his laptop is interfering with
Normal 0 Because you have the built in mike, in the laptop and the one in the camera working at the same time you will get distortion and feedback.
Go to Control Panel and Click on Device Manager. Then go down to Imaging Devices and click on the + and right click and then click on DISABLE. Then click OK
Or you could disable the Laptop Microphone but its more complicated to achieve.
Hope this helps. Bud
Jan 15, 2009 | Logitech QuickCam for Notebooks Pro...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
