Question about Sony Playstation 3 (PS3) Console
CONTROLLER PROBLEM Hi my controller stops working after about 2 mins use and thats with the usb cable connected cos it wont work without it oherwise.all the lights start flashing on the controller and even if i press the ps button so the controller hooks up to any of the ports it just wont happen.I have to turn the ps3 off and start again with the same results 2 or 3mins into any game
  • 1 more comment
  • Anonymous Dec 25, 2007
    Guitar heroes 3 controller not working, status lights on the Les Paul controller continually flash and the light flashes on wireless receiver. I've. tried all of the published troubleshooting suggestion;
    Checked connections
    Moved controller closer
    Checked Batteries
    Not in sleep mode
    Kept away from metal objects
    turned off wireless & cellphones
    any suggestion?
  • tbadmofo Jun 24, 2008
    my controller is fully charged, and when i unplug the usb cable the lights just keep flashing and it wont work. then when i plug it back in, the 1st controller light flashes and it workes,
  • muerte Mar 18, 2009
    I got that problem too, and is so frustrating, i even smashed one controller to the floor, buy a new one thinking that it was a problem with the controller but it still happend with the new one. sony got to pay attention to this problem becouse is a very expensive console and i dont think is fair to pay lots of money for a console that have this kind of problems and is a big big problem, something got to be done we want a solution !!!!
    Problem Solver:
  • 18 Answers
Try resetting your Controller. Using a paper clip, there is a small reset button on the underside of the SIXAXIS. Press it.
While your PS3 is still on, press the PS button on the controller.
Posted on Dec 12, 2007
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
Why wont it connect?
there is a sync button somewhere on the controller and the usb thing you plug into your Ps3, pres those at the same time continuosly put make a 2 second break untill it connects.
May 16, 2013 | PDP Afterglow AP.2 Wireless Controller for...
Manual for mcx-8 reactive controller
Controller and Analyser
Share: zero.gifzero.gif zero.gifzero.gifzero.gif Reactive power controllers MCE and MCX are designed to measure the reactive power of an installation and to give the necessary instructions for connecting & disconnecting capacitors in order to maintain the desired cos ö.
All the controllers are commanded by a microprocessor that ensures an uniform ageing of contractors and capacitors by using a circular connection sequence that takes into account the time that each capacitor has been switched on.
Power factor value to be reached can be adjusted in a continuous way, between 0.85 inductive and 0.95 capacitive.
Standard working programs for controllers are 1:1:1:1, 1:2:2:2, 1:2:4:4, 1:2:4:8 and 1:1:2:2.
*Item Code: MCEzero.gif
Description:
Power factor controllers MCE measures the cos ö of a supply system and control the automatic connection and disconnection of compensation capacitors according to the desired cos ö. They are available in 6 or 12 steps. To see the technical specification and for these steps please go to the attached Pdf file.
*The MCE-12F plus (12 steps) power factor controller measures cos ö in the system and regulates the automatic connection and disconnection of the capacitors depending on the required cos ö. MCE-12F plus is specially designed to control equipments with static switches based on thyristors, which operate through a zero step controller. *
These reactive power controller are designed to measure the reactive power of an installation by giving the necessary instructions for connection and disconnection of capacitors in order to maintain the desired cos ö. Controllers are show in a 3-digit display of the set-up or actual values. They show the cos ö, that the total current & the harmonic distortion.
All controllers are commanded by a microprocessor that ensures an uniform ageing of contactors and capacitors by using a circular connection sequence which takes into account the time that each capacitor has been switched on (FIFO system).
Controllers can include a fully operational alarm relay that acts when the automatic capacitor bank cannot reach the required cos ö in case of high harmonic distortion level, over-current and over voltages. LED indicators show permanently capacitors steps that are connected. To see these steps please open the Pdf file.
May 02, 2011 | Computers & Internet
I have a big ben ps3 controller, and when i push the ps button the red lights just flashing and then turns off, it just wont connect to my ps3.. please help!
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 25, 2011 | Sony Wireless Controller for PS3
2nd controller not working
Try this: Switch on controller 1 on, now hold down the PS button, now select Re-assign controllers and set this one as 1. Now turn it off.
Switch on controller 2 and do the same as above but Re-assign the controller as 2. Now power off.
They are both trying to grab the top spot at the same time.
If this doesn't work, connect that controller using the usb cable and do the same as above.
If the controller still has botth LED's lit when the usb cable is connected, then either the controller is faulty or the PS3 is at faulty and may have to but set back to factory defaults, do this first and if that doesn't sort it out then the controller is faulty.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
May 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 controller wont work unless hooked up to the system
Not sure if this is the same as my issue but worth a try anyway. I had tried 2 duashock 3 controllers with our 80GB system. Neither would work unless plugged in. Reset, left plugged in for hours, nothing worked. Tried a different USB cable and worked right away. I let if charge for a few minutes and unplugged it, still worked. I did notice that when I was using the first USB cable that when I checked status of the controller (charge, controller assignment, etc) it had a "-" instead of showing a charging animation. Hope this helps.
Jan 11, 2009 | Video Game Consoles & Games
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Sony Playstation 3 (PS3) Console Logo
393 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
