Black & Decker 1/2" 13MM, Heavy Duty Vsr Drill, 0 - 850 Rpm, Helical Cut
Problem for Black & Decker 1/2" 13MM, Heavy Duty Vsr Drill, 0 - 850...
Black and decker cordless drill trigger
By baileslegend on Sep 08, 2009
i have a 18 volt blck and decker cordless drill model is KC1882F the trigger has stopped operating it will not depress to operate the drill
Best Solution
posted on Sep 12, 2009
Very Helpful)
VtToolMan
Rank: Guru  Tools & Hardware  Expert
Rating: 97%, 774 votes
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Black & Decker 1/2" 13MM,
Questions and Unsolved Problems for Black & Decker 1/2" 13MM,
Do you recommend Black & Decker 1/2" 13MM, Heavy Duty Vsr Drill, 0 - 850 Rpm, Helical Cut?
Answer
Answer
Need parts for a Hilti TE 17 - specifically a chuck or parts for the chuck
Answer
i think something may be wrong with motor... was miing something to thick and now when i pull... (More)
Answer
where can I find a 75 rpm ac or dc motor, not a gear motor, and around 1/15 hp
Answer
I was replacing the power cord. The red wire, which is attached to the white wire on the power... (More)
Describe your Drills problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Drill Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
