Question about Brother MFC 210C All-In-One InkJet Printer
My Brother 210 C printer stopped printing black with a full ink cartridge.
    President:
  • Brother Master
  • 1,447 Answers
You reset ink cartridge counteror buy a new one black cartridge
Posted on Sep 09, 2009
  • Sazeed Computer
    Sazeed Computer Sep 10, 2009
    clean or maintainence your cartridge and reset ink counter
  • Sazeed Computer
    Sazeed Computer Sep 11, 2009
    buy a new cartridge or wash with water your cartridge head withen 8 hours then dry ink is soft and print again
How can I stop the colour ink cartridges from printing and use only black ink?
Hi and welcome centrecourtm !
You can fool the printer bij making it believe the color cartridge is full .
Go here to read about the trick :
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Good luck !
fanaudi .
Feb 20, 2011 | Brother MFC-260C All-In-One InkJet Printer
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
How can I print in " Black ink only " NO COLOR ?
go to control panel
printers and faxes than right click on the driver for the printer and click on properties ...
and you will find the option to print in gray scale
Dec 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
I have a Brother DCP350 and no yellow ink. But tonight I have to print a document. Will the printer work without Yellow? I have been trying for an hour now and cannot print anything.
Hi matt651, I had the same problem with the DCP-350. As soon as one of the colour cartidges was empty, which happened frequently due to the high ink loss during the cleaning process, the machine stopped working, even when I only wanted to print using black. This is how i worked around the problem using a piece of grey card stock: The tanks have a small clear window that lets you see the ink in the cartridge. This window also triggers a photocell which sits in a little black fork at the back of each of the printer's ink cartridge slots. When the ink levels are up, the cell is blocked, thereby indicating a full cartridge. When the ink level in the cartridge drops below the photocell, the cell switches over, indicating an empty cartridge. So in order to simulate a full ink catridge I removed the offending empty one and instead slipped a piece of cardboard into its slot, thereby fooling the photocell. And hey presto, when I switched the printer back on, all ink cartridges thus manipulated were shown as being "full" and I could continue printing.
Kind regards, Rog
Nov 27, 2008 | Brother DCP-350C InkJet Printer
Brother MFC 3240 wont print when 1 ink is empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 24, 2008 | Brother MFC3240 Multifunction InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
159 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
