Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster Key Pad
I have a liftmaster 1265-267 Screw type garage door opener. The issue I'm having is with the keypad which is a 976LM. I have a 4 digit code that works but sometimes we have to enter it 2, 3 or 4 times before it opens the garage door. In the cold, it's even worse and sometimes doesn't open at all. I have replaced the batteries many times with no success. Is this common with keypads? If I need a new one, which one is recommended?
  • 4 more comments
  • goinsw Dec 11, 2007
    i have to re-enter the code 3 to 5 times sometimes. what up with that?
  • FeatherEB Jan 07, 2008
    We are having the same problem. My husband leaves at 6 in the morning and since it's been below freezing our keypad won't work at all. I guess it's just freezing up. Please if anyone has any answers I'd be happy to have them.
  • Anonymous Jan 07, 2008
    Me 2. I hate this keypad. I even have problems when it's simply raining. Piece of ***t.
  • RMAL Jan 10, 2008
    I have the same problem. My keypad was working after entering it a few times and now it just doesn't work at all and I can't get into my garage!!
  • Anonymous Sep 06, 2008
    I have the same problem. Multiple entries required to open the door, and now it is not functioning at all. I agree, piece of ***t. I am an electrics engineer and thought I could fix it, but its not made to take apart, threw it away.
  • Anonymous Nov 22, 2008
    We have the same problem. Once the temp goes below 35 degrees the keypad won't work. We have also tried changing the battery several times. The remotes and the car remotes work just fine. It's very frustrating to have to remember to take a remote with when you leave to walk the dog or you're locked out!
    Help please!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Yes, this is a common problem. I recommend the Domino GD-1. It is a wired keypad but the batteries are on the inside so they stay warm, plus you can use from 1 - 6 digits instead of just 4. It is harder to install but worth the effort.
It does not come with wire so you will have to get some bell wire.
Posted on Feb 07, 2009
Can not reprogram key pad on my liftmaster garage door opener ,tried every thing in the book ,hand held works and also i am able to open and close from the multi function door control.
If you are sure the battery is good and this doesn't work then you need to replace the keypad.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you open the battery compartment in a key pad to change the battery?
Some have a small screw that must be removed and others slide down. It depends on the model.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster key pad isn't working at all. I
There should be a small phillips head screw and then the cover slides down.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
LiftMaster 1/2hp: Key Pad Won't Work!
If you have a wireless keypad replace the battery.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door is also on a key pad. It will not
COULD BE A WEAK BATTERY IN THE KEYPAD THE DOOR ACTUALLY RESTRICTS ABOUT 5-10% OF THE SIGNAL STRENGHT
Apr 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Instructions for light cover removal
There are two plastic divets on the cover you can get a flat head screw driver. Depending on the age it may be brittle. Thanks BB
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my chamberlain garage key pad, after the liftmaster repair guy erased the code? What do I push on the keypad, while holding the green liftmaster learn button? thanks
hope you have not held green button or your renotes will bew erased. Push green button for one second. Go to keypad. Enter 4 digit code and hit ENTER. Bulb on motor should blink. That's it.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
577 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
