Question about Car Audio & Video
Need car stero code for peugout 306,meridan.y plate
Need car stero code for peugout 306,as mine not working since battery on car died.
  • 4,919 Answers
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning withBP or  RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , Halfords or email us for details ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
Posted on Sep 08, 2009
Peugeot 306 52 plate,pulled out the garrage one morning all perfect,left for 30mins tried to start to go to work turns over but wouldn't start,tried everything even diognostic machine of mine and the
Did you check for fuel pressure with a gauge on motor
or scan tool, if that data is avail?
Did you put one of those HEI Spark Plug testers in a plug wire
or cop coil
Do the cams turn
I'm not into the Peugeot, but is expect you may have a timing
belt ?
You may not have data on the ignition switch & its contacts
Do you have battery voltage to the ignition & injectors with key on
Injector pulse when cranking ( crank sensor !!)
Jul 26, 2013 | Cars & Trucks
How do i fix my car radio
you have aq anti teft stero your un lock code should be in your owners manuel
Apr 23, 2013 | Car Audio & Video
How to reset the stero in a mercedes
I assume you have the radio code that came with the car????Disconect the battery cable and reconnect,that should reset the radio where you can enter the code.You will also have to reset the windows by holding down thw window switches once the reach the lowest and highest travel.the face plate on the radio should say code to be able to enter the code.
Feb 12, 2012 | 1999 Mercedes-Benz CLK
I HAVE A PEUGOUT 306 AND I NEED THE CODE FOR THE STEREO. MODEL PU2294A, SERIAL CL0401Y0208606 CAN YOU HELP PLEASE
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If you have this barcode serial number then
POST ANOTHER QUESTION              with these details
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Sep 29, 2009 | Panasonic DMR-E85H DVD Recorder
Radio code
More than likely, you need the model and serial off the radio itself. Call Nissan, pretend ur calling from a local stero shop to request code... worked for me...
Jul 06, 2009 | Car Audio & Video
Battery died, stero won't work. have some #'s on key remote start but don't know what to do
if its a factory radio you have find a dealer if its not you dont need the code just take the face off and push rest button
May 04, 2009 | Car Audio & Video
PUGEOT 306 SOUNDS LIKE A TRAIN/MOTORBIKE WHEN SLOWING DOWN
check the exhaust if the cat converter has let go these cars get very noisy you can check the cat by banging on it and checking to see if it rattles if it rattles it is no good.
Nov 06, 2008 | 1989 Peugeot 405
Open Questions:
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
