Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
TRIMMER WITH NO SPARK. - Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Gas trimmer has no spark
troubleshooting Gas trimmer has no spark
Jun 20, 2015 | Troy-Bilt TB32EC 17" 25cc 2-Cycle Straight...
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
Fuel hoses and filter need replacing and a spark plug for a Talon AT3351A line trimmer
The manual has some instructions for doing these tasks on the Talon At3351a Line Trimmer. Here is the link for the Talon At3351a Line Trimmer manual.
Jan 21, 2013 | Garden
25cc Craftsman line trimmer: - will not start. - no spark across the gap of the plug - plug shows no corrosion.
Hello there and thank you for choosing fixya
normally on these when you dont recieve a spark and you are 100% sure that the spark plug is good than the only thing left to check is the ignition coil
It is what the plug wire is connected to kind of a square or round part these are nortorious for going out in small engines this is a 35 dollar part ok?
thee if this does not do it check the on off switch for continuity
Then finaly Check the flywheel cover, the magneto gap and starter coil if there's still no spark.
Read more: How to Troubleshoot a Small Gas Engine Trimmer ' eHow.com http://www.ehow.com/how_6306856_troubleshoot-small-gas-engine-trimmer.html#ixzz1LrUTc28o
May 07, 2011 | Craftsman 25cc Gas Line Trimmer
TB75SS Troybilt Gas Trimmer
did you put the spark plug in the wire & hold it against the head or just the wire if you help just the wire against it it wouldn't be right cause they don't have a spark long enough just from wire let me know thanks wade
Jul 06, 2009 | Troy Bilt Tb70ss Gas Trimmer
Starting Still FS55 Trimmer
try leaving the trimmer in direct sunlight for a while and then try starting it. placing the trimmer in direct sunlight will warm up the spark plug. if it does start then it might be that spark plug is getting to be weak and may need to be replaced.
May 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Have a mucculoch line trimmer that does not get spark
Can only be a few things 1, bad switch,2,bad wire to switch 3, bad module,do you have a spark tester? how are you checking it?
May 12, 2009 | Garden
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
85 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
