Question about Samsung Computers & Internet
Getting a message Module 0 of 74.227.11.195 is not ready, or network bad after logging in websamsung.net
How to fix code U0155 for 06 Ford f350
Gas or diesel ?
U0155 - Lost Communication With Instrument Panel Cluster Control Module Description: Missing message concerns are logged by a module upon failure to receive a message from another module within a defined retry period. Possible Causes:
  • Open VPWR circuit to the sending module
  • Open GND circuit to the sending module
  • Open network circuits to the sending module
Diagnostic Aids: Carry out the diagnostics for the associated network module. Application Key On Engine Off Key On Engine Running Continuous Memory All Refer to the Workshop Manual Section 413-01, Instrument Cluster. Do you have a scan tool that can talk to the I/P cluster ?
  • The instrument cluster does not respond to the diagnostic tool
  • Circuit or connection in the controller area network (CAN)
  • Instrument cluster
  • Go To Pinpoint Test H .
May 12, 2015 | Ford Cars & Trucks
Sc28103@windstream.net
Point your web browser at http://www.facebook.com
If another account comes up, log out of it by clicking the down-pointing triangle in the upper-right then clicking "Log Out."
If you then still can't log in to your account, click the "Forgot your password?" link located just below the password box on the login page.
If you're getting an error message, what does it say?
Aug 21, 2014 | Facebook Social Network
I received an EIO error message and looked it up online. The answer said to move the EIO from one slot to another, which I did. The error message is gone, but I can't get the printer back online.
Do you mean the printer won't come READY?
Or do you mean that you can't get the printer on the network?
Print out the CONFIGURATION Pages. The last sheet should be the network info.
The top left should have a statement "I/O READY".
If you get NOT READY, you probably have a bad JetDirect.
If it is ready, check the IP address on the right side, make sure that it is correct.
Try reseating the Jet Direct (with power off).
Jan 20, 2011 | HP LaserJet 4250dtn Printer
Login page of facebook is not getting open.why?
hi,
Whats the error message?
Try and log in to differnt computer or contact facebook by clicking the link below and in the drop down select "Report a site problem"
http://facebook-developer.net/contact/
Dec 22, 2010 | Facebook Social Network
I can get the cell back up to work on my simon 3
The vell module is not like a cell phone. It is specifically set up to go to the alarm.com network. You need to have an alarm company involved. Alarm.com can send you e-mail or tect messages if you have a smartphone, but you are going to be about $25-$30 per month to get that service.
Alarmprofessor.net
Mar 05, 2010 | GE Security Simon 3 Wireless Home Security...
I could not do Map Network Drive from other pc to my Dell Inspiron 1501. It looks like security setting is violated. I got message saying 'c' is available but the user account that you are logged on with...
If you are using Window's XP or later the problem is probably the account you are logged into doesn't have "administrative access". You will have to log into the administrative account to make network changes.
If you are running Vista the default administrative account is hidden. To access it do the following: First you’ll need to open a command prompt in administrator mode by right-clicking and choosing “Run as administrator” (or use the Ctrl+Shift+Enter shortcut from the search box)
Now type the following command :
net user administrator /active:yes
You should see a message that the command completed successfully. Log out, and you’ll now see the Administrator account as a choice. (Note that the screenshots are from Vista, but this works on Windows 7)
You’ll note that there’s no password for this account, so if you want to leave it enabled you should change the password.
Disable Built-in Administrator Account
Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:
net user administrator /active:no
The administrator account will now be disabled, and shouldn’t show up on the login screen anymore.
Feb 05, 2010 | Computers & Internet
Cannot connect to wireless network
sure..e net is a direct connection..so that means your computer is ready..if the network you are seeking is not showing up, then you are most likely too far away, or you may need to refresh the network reading panel, until it opens..
Oct 13, 2008 | Dell Wireless ( 57fuy )
Camera module not working of model s3
camera module of china mobile model-ztc 220 is not working displaying the message,camera module not ready....
pls assist me as soon as possible
Jun 30, 2008 | Handmark Software MobileLists (950142) for...
Internet viewing of my home security system
Frank, if you have an external IP, you can open a port on your router and viewit that way. Works great for me. ANyone know how to view the system with Vista??
CAD...
Jun 20, 2008 | Samsung SSC DVR Digital Video Recorder...
Unfamiliar Error message:
This seems to be related to a network problem, specifically, authentication. Has anything been changed or upgraded recently? There are a number of references to the error on the internet. I have attached them below.
Firstly, one user has looked at the /var/log/messages log file and found the additional error "uam: uam not found (status=-1"
Can you check that log?
A fix suggested by one user is:
"Turns out I needed to update the nettalk version that was included with YDL 2.3 to version 1.5.3.1-1c. After that and a restart apple talk works perfectly, on both our os9 and X machines." Maybe there is a lead there.
Attached bits from other users below.
Apparently, this error is "-5002 afpBadUAM: AFP Bad UAM," something to do with the User Authentication Module.
I've looked in var/log/messages
>>and it says : uam: uam not found (status=-1)
http://www.yellowdoglinux.com/support/solutions/ydl_2.3/netatalk.shtml
Good Luck. If you need to talk further, pls post it here. Rgds,
May 08, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
252 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
