Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
  • Jeremiah Johnson
    Jeremiah Johnson Oct 31, 2018
    I HAVE TRIED ALMOST EVERYTHING AND FINALLY I FIXED THE PROBLEM WITH RUNNING THIS TROUBLESHOOTER. JUST RUN IT AND IT WILL FIX THE PROBLEM AUTOMATICALLY.
    CLICK BELOW TO DOWNLOAD THIS TROUBLESHOOTER:
    >>>>>>> CANON TROUBLESHOOTER
    I HOPE IT WILL HELP YOU. PS IT'S NOT MINE AND I AM JUST SHARING IT HERE...
This works!:
Best Solution posted on Sep 05, 2009 trying to scan, but keep getting error code 2,162, - 4%20ratings_thumbs.gif
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Posted on Oct 21, 2009
2 Suggested Answers
SOURCE:
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
CANON PIXMA SCAN CODE 2,151,44
I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Canon ImageClass MF6540- works fine for printing, but scanning complains connection problem on Dell Dimension E521. However my other Dell Dim 9200 computer runs fine for both printing and scanning. What...
Need some clarification about the error.
We need to know the exact error.
Generally all the scannars use TWAIN technology which bridges the scanner with WIA(windows imaging aquisition).
We need to know if WIA which is a part of the operating system is working. For diagonasting we can try using teh scanners and camera wizard from control panel or we can use mspaint even.
If WIA is working in that case the problem may be with the registry values of the scanner.
WE can try making a new user account with admin rights and then we can try installing the scanner. We can even try using Revo uninstaller for uninstallation of the scanner because it will remove all the entries from registry, then we can try scanning.
BEST OF LUCK.
Feb 11, 2010 | Canon ImageClass MF6540 Copier
Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Jun 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP scanjet 4370 focus problem
adjust the brightness resolution or default settings for scanner while scaning. Also read the manual of the scanner.
Aug 25, 2007 | HP Scanjet 4370
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
20,143 people viewed this question
Clive
Clive
old marine
old marine
Ekse
