Question about Epson Stylus Photo R800 InkJet Printer
Printer not printing any yellow
Having not used the printer for sometime it will not print any yellow at all. I am using genuine epson cartridges , and have almost spent as much on cartridges as a new printer , just in cleaning cycles !!!
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
Just put new ink cartridges in, but yellow is out. Do I need full yellow cartridge in order to print? Printer is not printing.
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
Mar 25, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Ink not recognized sx215 yellow
You do not mention your model and brand of printer..........................
Mar 23, 2010 | Epson Office Equipment & Supplies
My printer epson is printing yellow background with any document i print. what can i do to stop this
Feb 16, 2010 | Epson Stylus Photo 820 InkJet Printer
I JUST PUT IN NEW INK CARTRIDGES IN MY CX6000. THE BLUE ONLY SHOWED ON PAPER THEN ONLY YELLOW CAN YOU HELP ME PLEASE
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 15, 2010 | Epson Stylus CX6000 All-In-One InkJet...
The R1800 has not been used for a long time and it does not print. I have shaken the print cartridges but it is not being recognised as full when I want to print. What do you suggest I do??
Change all the cartridges to Epson Genuine Cartridges.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
Feb 09, 2010 | Epson Stylus Photo R1800 InkJet Printer
Printing problem
Did you use Epson Genuine Cartridges? ???
Feb 08, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
My Epson color printer 880, prints erratic and very small print in a light black and sometimes blue color
Dec 17, 2009 | Epson Stylus 880 InkJet Color Printer
Wont print black or yellow ink
Dec 16, 2009 | Epson Stylus C64 InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo R800 InkJet Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
