Question about Health & Beauty
RS 4i won't power up
The short version is RS Medical informed me there is no tech support that can talk to you by phone that repairs are done in some warehouse location. Units are to be sent to RS Medical and repair cost may be covered by insurance but if not cost is passed back to the customer. Units are not to be opened by users as that disables the program. I believe it is all a rip off. My unit would not power on with a charged battery so I did order a replacement battery pack and it continued doing the same thing. Both battery packs test good with battery tester. However there is also a 3v button cell battery built into the unit that test bad but RS customer service could not tell me the function of that battery. I am thinking that battery may be the culprit of my problem. I am capable of changing that battery but would still need to know if anyone knows how to reset the unit.
Does anyone know of a doctor or field representative that may be knowledgeable of these devices?
The 3v battery supports the program info,if it goes bad, u have to send in and they will replace battery and reprogram for u. that is as long as the sysytem is paid for, after one year of service, unit shuts down and u have to call in and they will walk u through entering a code to reset. as long as there is a zero ballance. mine has a bad powerpack 6v 2.1ah 0525 battery, if u have an extra i sure could use. contact is cphlah@yahoo.com. i am in louisiana. thanks
Posted on Nov 05, 2009
I had a gas leak coming from the female or male fuel line connector I repaired the plastic connector but the bike still won't start.
Hi, Denim and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
8. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
10.. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
11. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
12. Faulty neutral, clutch lever, or kickstand safety switch.
13. Faulty fuel pump or fuse or relay.
14. Tilt sensor needs a reset.
15. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
955i won start Problem Solving Tech Forums Messageboard Triumph Torque
Sprint RS Starting problem
Topic 2005 Triumph Daytona 955I Will not Start Read 8797 times
Triumph Sprint RS 1999 2004 Factory Service Repair Manual Download Manuals...
Jun 08, 2016 | 2001 Triumph Sprint RS
Tip
Contact Information For Manufacturers Tech Support
Contact information for Manufacturer's Tech Support and Repair Services for Power chairs and Scooters
Pride Mobility 1-800-800-8586 pridemobility.com
Sunrise Medical 1-800-333-4000 sunrisemedical.com
Merits Health Products 1-800-963-7487 meritshealth.com
Invacare 1-800-333-6900 invacare.com
Shoprider 1-800-743-0772 shoprider.com
Electric Mobility 1-800-257-7955 rascalscooters.com
Hoveround 1-800-96-HOVER hoveround.com
Repair Services
Roadrunner Mobility 1-800-467-2668 roadrunnermobilty.com
XMed Repair Xpress 1-877-581-3733
on Jun 28, 2011 | Health & Beauty
I have a RS Medical RS-4i Stimulator that stopped working. can you tell me how to restart it. My insurance purchased this machine for me and I no longer have them the machine is 10 years old. They told me...
https://static1.squarespace.com/static/54f4f4aae4b00accfaa5f9b4/t/551340cce4b0beedea4435c0/1427325132294/RS-4i+Plus+IFU.pdf
Setting that is permanent and will never have to be reset. Unplug machine when screen goes blank push the power button and press the channel #4 minus until you get the setting screen. Start with channel #1 and set it to A channel #2 set to B channel #3 set to the number 6 and channel #4 set to A.
Jun 06, 2017 | Health & Beauty
I am an attorney and I am looking for an expert witness on a faulty wheelchair repair can you help?
Your best bet would be to look in the yellow pages under Durable Medical Equpiment to find a local wheelchair/scooter sales & service shop in your area, and ask if they have repaired an Invacare chair before and are familiar with it and can help you.
Another option would be to contact Invacare AS A CUSTOMER and ask to speak with Technical support, see if they have a local field tech who might be able to give you technical repair information over the phone. They probably won't give you the Tech's name and phone, but if you give them yours, the person may call you back and you can give your proposal from there.
I'm with Hoveround, so my knowledge on other brand scooters and power chairs is in general info. I hope this information is helpful to you!
Nov 10, 2010 | Invacare Pronto M51 Power Wheelchair
Wurlitzer CDM 4i Blowing fuse 5 and no display
You have either a defective amplifier board, Selection and Credit Computer, or short in your wiring. I can help troubleshoot via phone or email. Please email tech@wurlitzer-ohio.com
Jan 20, 2010 | Wurlitzer Jukebox CD Player
Is there any reset code for RS-4i stimulator?
If "you got your stimulator" with a prescription and own it just call RS Medical & they'll reset you for free on the phone. That's what I did. No problem. Then a month ago I dropped & broke my unit so I thought I'd buy another on the internet since I'd paid RS over $4,000 on my orig machine & some supplies, and could find them cheaper on ebay etc. Then I called RS for a reset, they asked for the serial number, and I learned that not everyone OWNS "their machines". The one I'd just bought was a never returned LEASED item that many return demand letters had been sent out on. In other words, I was sold STOLEN PROPERTY. RS Medical wanted their unit back. I wanted my money back from the seller. Paypal WAS NO HELP. The replacement I bought has been flagged as stolen & will never be reset ---- don't get yourselves in this crappy position people, it's not worth it. Go to a Dr., get a prescription for the device, hope your insurance will pay a good chunk of it, and MAKE SURE IF YOU'RE BUYING ONE ON THE INTERNET YOU ASK FOR A SERIAL NUMBER OF THE MACHINE & CALL RS FIRST TO SEE IF THE SELLER REALLY OWNS IT (& this is hard enough working around the HIPPA stuff..), but they'll tell you if it's THE PROPERTY OF RS MEDICAL!!!
Jun 23, 2009 | Health & Beauty
Need reset codes to rs-4i stimulator
it will,nt turn on need a code when it does turn on to use it
Feb 24, 2009 | Computers & Internet
I have a RS Medical RS-4i stimulator , how do I reset it ?
This is the code that I was given about 7+ years ago to reset our RS Medical RS-4i Stimulator and it worked fine.
Turn unit on & press ch. 4. Then you press ch. 1 until it shows a "F". Then ch. 2 until it shows a "7", ch. 3 until it shows a "B", & ch. 4 until it shows a "A".
Hope this helps.
Jan 18, 2009 | Computers & Internet
Health & Beauty Logo
1,653 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
