Can't get into my router. have put in my ip address and it comes up as internet has stopped working
    Novelist:
  • 136 Answers
Deckyscanlon --
Couple things...
Is your router a seperate unit from your modem? Is it a wireless connection? If so, power down your modem, your router and your PC. Then power up your modem, wait a minute or two for it to initialize, power up your router, wait another minute to allow it to detect modem, and then power up your PC.
This should get your router connected. If you are now able to see your router (through http://192.168.2.1, or http://192.168.2.1, etc <--- whatever your IP address you are using), you may be able to see your modem from your router's page.
If the router is still offline, try a hard-reset of the router... sometime there is a reset button to press and hold, sometimes a pin-hole to put a small paper-clip (GENTLY) into to press button. You will have to configure the router again for your use, but should be at least able to get connectivity.
If you need to check your IP settings from your PC, you can find them like this:
Start button ---> Run ---> type "command" and click run ---> at the prompt, type "ipconfig /all", and your network settings will be listed. type in "exit" (when you are finished noting the addresses you need) to close the window.
If your are able to get connected to the router, but the internet is not functioning, try a hard-reset of your modem (refer to modem's user guide), and check your Network settings. If you are using a dynamic IP address, your PC should detect the modem through the router and connect from there. If you are using a static IP address (fixed), check your internet service providers information for the correct settings (DNS gateway, etc)
Your modem may have a "series" of lights that either blink normally, or perhaps blink "in code" (like, two flash intermittently at the same time). If there is a problem between your internet service provider and your modem, the error will be evident from the "flashing" (again, check your modem's guide for "error" codes.
Whew! It can get a bit involved, but hopefully your router just needs a re-boot!
If you continue to have issues, post a comment to this thread, and I will be happy to assist you further!
Hope this helps!
-- RT
PS - If useful, please don't forget to vote!
Posted on Sep 08, 2009
  • Roonie Tunes
    Roonie Tunes Sep 08, 2009
    PPS - Sometimes even just right-clicking on your wireless adapter (usually in the program try at the bottom-right portion of your desktop) and clicking on "repair" will disable your adapter, re-enable it and re-acquire your IP address... maybe try that first and see!
    -- RT
Tv will not connect to internet
It sounds like your router is not assigning an IP address to the TV. If you have already have DHCP turned on, in the router's settings, then you may need to increase the range. If you are not using DHCP by choice, then you will need to assign a static IP to the TV. You may also need to configure the TV's MAC address in the router's settings, if you are using MAC address filtering.
Are you the person that set up the router, and is this your router? Some additional information is required, to be able to assist you.
Sep 16, 2014 | Computers & Internet
My internet Connects perfectly to the computer to the modem.. but when I put my router inbetween the two, it stops working and i've tried everything including restore factory settings, and it still...
Well in order to access internet via your router, it needs to be configured as you said its being restored to factory defaults. Also always mention your ISP (Internet service provider), Router model no and Computer type with running Operating system for exact steps to fix such problems
Alright, first of all we need to establish physical connection with the Modem -> Router->Computer, then we will setup router
  1. Connect Ethernet cable from Modem to the WAN port of the router.
  2. Connect another Ethernet cable from Router LAN port to computer LAN port.
  3. Power cycle all the devices (Turn on Modem first, then Router and at last computer).
  4. Usually in case of Cable ISP, router would automatically get connection from Modem and Internet should start working.
  5. Else you can open Router admin page to configure
  6. You need to find the IP address of your router (usually Default IP of Netgear routers is 192.168.1.1). I can't tell what is the IP for your router as you didn't mentioned Model no.
  7. Open Command prompt (Start-Run-CMD) and type IPCONFIG.
  8. Default gateway address is the IP address of your router. (You can also find router's default IP on the its panel below.)
  9. Now next step is to access router interface.
  10. Open Browser and type http://192.168.1.1 (It is just an example, you need to use the IP address of your router, we are assuming its 192.168.1.1). Press Enter
  11. Type "admin" in usename and "password" in password box to login (both are in lower case without quotes)
  12. In the left side you can find Setup Wizard, Click on Yes and then Next
  13. Wait for the process to complete and then hit "Apply".
Ask me any questions if you need any help. Hope this helps.
Jul 13, 2011 | NetGear Computers & Internet
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
I have a advent milano w7 when try to connect to the internet via wireless router. connecting to router but not to the internet when running diagnostic report it comes back saying that it may be the afw...
In you r network adpater setting;Set the router IP address as your Default Gateway IP address
and In the primary DNS setting put the DNS address your Service provider.
It will work
Dec 25, 2009 | Advent Netbook
When I turn on the wireless on my Vaio laptop running vista, the wireless network I having running through a linksys (wrt54g) router stops working.. sometimes after restarting the router it will work for...
The Problem you are having comes up because you probably put on your router before putting on your Computers, including your laptop.
What I would advise you to do is that, always try to put on your Computers first, before turning on your router.
This will make your router to dynamically distribute IP Adresses to your computers and therefore reduce conflict.
And if at any time, you make a mistake of putting on you router before your PC, just switch off your router for 2 Minutes and switch it back on.
It will enable your router to renew IP Adresses to all your Computers without having conflict.
Then Always remember to make your Computers Obtain IP Address Automatically, and your Router Should be set to use DHCP.
This Solution is an exact solution that I used in my office last week, so its proved to work.
Hope this helps you out.
Keep me posted about the problem.
Goodluck
Nov 21, 2009 | Computers & Internet
Can't Connectda
Restore your router to factory settings, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses on the router.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be 192.168.1.100 or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Network
as long as you are not using your own router to connect to your neighbours, as this wont work only one router on the network can connect to the net Im assuming your pc is trying to connect to the neighbours router, so you need to reset the router if you cant access it, it should have no password as default and the ip address of the router should be 192.168.2.1. get into your network cards properties and ensure obtain an ip address automatically on the TCP/IP line is selected. Go into the router settings and make sure enable DHCP is set to allocate ip addresses automatically and that the router transmits on mixed mode b and G, turn off any wep or wpa encryption until you have a connection. Do not use windows connection repair as it will totaly mess up your pc's ip addresses and stop you from connecting to the routers ip address.
Aug 28, 2007 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
314 people viewed this question
David Payne
David Payne
