Question about Dell 1815dn All-In-One Laser Printer
Dell 1815 dn - bogus front door open message
My dell 1815 dn has the front door is open message and it won't go away. Any suggestions are appreciated.
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS.
Posted on Jun 16, 2011
  • Steven C
    Steven C Sep 22, 2011
    This video was updated herehttp://www.youtube.com/watch?v=d2JENLgZQ... to include removing the front door and fuser prior to installation
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
Dell 1815 keeps saying door open when it is not.
The front door switch has gone bad which is part of the High Voltage Power Supply. You need to replace the HVPS (part# WH773). This should clear your problem right up. Iteminc.com has this part and ships same day.
Jun 08, 2011 | Dell 1815dn All-In-One Laser Printer
Currently have a Dell 1815 - keeps saying Front door is open and will not print. Have tried everything - from turning off printer, unplugging, changing toner, etc.
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Sep 15, 2010 | Dell 1815dn All-In-One Laser Printer
Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Aug 18, 2009 | Xerox Phaser 8500/DN Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Front door open message on display of dell 1815dn printer
May 21, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
1,173 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
