I have a Maytag Perform dryer. In the middle of a load, stopped working. No light on when door is opened as well. Plug is in, no breaker tripped in fuse box either. HELP!
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Does the maytag dryer have a reset button. The dryer was working fine then just stopped turning on.
No, they typically don't have a reset button. But they do have safety switches which can fail. Usually there is a microswitch on the door. When the door is open the dryer won't start. Do you have power at all to the dryer? Do any lights light up? If not, you may have tripped your circuit breaker to the dryer and need to reset them. Typically there will be two breaker switches tied together to move as one in your power panel for your house or apartment. If you are not sure the breaker has tripped, it won't hurt anything to switch them off and then back on again. If this does not help, you likely have a failed switch or relay in the dryer that will need to be replaced. Also check that your lint trap does not have a switch which will prevent to dryer from running if you have too much lint in it.
Nov 04, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Light out but light bulb still works
HERE is a trouble code chart for your machine
If the breaker constantly trips, the unit has a short & possibly no codes will come up for this reason
I would check the circuitry for plug in cord first to the washer for a possible loose connection
http://www.applianceaid.com/neptune8.html
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer stop in the middle of drying and wont come back on
Locate and check the circuit breaker. It should be a Double-Pole breaker of 30 amps or so. Turn it off and back on to make sure it is not in a tripped condition. Be sure there is nothing stuck where the door closes. And that you can hear the door switch "click" when you open/close.
May 04, 2009 | Maytag PYE2300AY Electric Dryer
Maytag frontload dryer
hi THE THERMAL FUSE IN THOSE DRYERS CAUSE THIS PROBLEM rEMOVE THE FRONT PANEL 2 SCREWS ON FRONT AT BOTTOM REMOVE . THERMAL FUES IS LOCATED ON THE VENTING TO THE LEFT OFTHE ELEMENT .THANKS THEAPPLIANCE DOC
Jun 22, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
