Question about Kenmore 24032\24036 Top Load Washer
Agitator stopped moving. it started off making noice then it stop moving period.
Agitator doggs 15$ at your local appliance store. If you arn't good with tools call someone who is. I hope that helps.
Posted on Sep 08, 2009
Car just started making small whistling sort of noice but stops once I start driving. It gets louder if I put on air conditioner.
HI Ann:
With the engine off, check the tension on the serpentine belt. Also, try spraying some conditioneron the belt. Safety first!!! Watch your fingers and moving parts.
Apr 08, 2015 | Cars & Trucks
Washer will not run continously starts agitation then stops, waits a short period and attempts to run again only to stop again and repeats this process
Mate seeing theres no model or make of your machine, it does sound more of a comms error between the controls & motor drive sensors.
Jun 08, 2011 | Washing Machines
I have a 01 manual neon and it makes a clunking noice when i start moving from a complete stop, it doesnt make the noice all the time but most times and only in 1st when starting
sounds like your c/v axle bearings going bad replace with a remanufactured cv joint also make sure no loose parts on front caliper to brakes too! good luck
Jul 12, 2010 | 2001 Dodge Neon
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Noices
there are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Nov 06, 2007 | HP Compaq Presario SR2150NX PC Desktop
Kenmore 24032\24036 Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
