Question about Motorola Mobility RAZR V3
Phone powers off when closed...
When I flip the screen closed to store it, the phone powers off.
The screen of my lg-vx9200 isn't working, what should I do?
Hello, problem is from the flex. The flex is connected to the screen. Sometimes the flex
worn out and the screen won't display. The flex is connected to the phone board. This is common with flip and slide phones. The flex worn out as a result of constant opening and closing of the phone.
Have the flex replaced and phone display should be restored.
Regards.
Jan 06, 2012 | LG VX9200 Cell Phone
MY SCREENS ON MY MOTORAZR2 V9 HAVE BOTH GONE BLANK, IT IS AN OLDER PHONE BUT I REALLY NEED MY PHONE FOR WORK. I AM OUT OF TOWN AND CAN'T GET TO AN ALLTEL STORE TO GO GET IT FIXED OR A NEW PHONE FOR TWO...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Dec 06, 2010 | Cell Phones
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
My blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
Jun 16, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Frozen motorla razor phone
most carrier retail stores have cellbrite machines and can retrieve your numbers so long as the phone powers on
Mar 24, 2010 | Motorola Mobility V620 Cellular Phone
UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Mar 31, 2009 | Motorola Mobility i880 Cellular Phone
Open/closing diaplay problem
replace your phone
Oct 07, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
