Question about Coffee Makers & Espresso Machines
Start coffee machine and electricity of the house got gone
Hi, I wanted to start the coffee machine, but the electricity of the whole house went off right after I pressed the 'start' button. I had tried again, but the electricity still got gone. Its a Delonghi Caffe Corso. We just bought 3 or 4 months ago. can anyone help and tell me what cause that?
Thank you very much in advance!
Monica
  • 2 more comments
  • monicafay Sep 08, 2009
    oh, actually it trips the main breaker to the whole 2nd floor of the house. the electricity for the 1st floor is fine.
    I am unsure of the total amp, but its been working well for the past 3 or 4 months, never tripped the main breaker of the 2nd floor until today. after it tripped the main breaker, i turned the main breaker ON, but it triped right after i press the 'start' button of the coffee machine. maybe there's something wrong with the coffee machine?
    Thanks for sending me solution again. Before I read what you just sent, I was downstairs with the coffee machine to the downstair. it triped the main breaker of the 1st floor almost at the same time when I pluged. I guess there must be something wrong with the coffee machine then.
    Anyhow, thanks again for sending solution to me!!
  • roberta3fan May 11, 2010
    It trips the main breaker to the whole house?
  • 574 Answers
K, do you know in the breaker box for the second floor what is the total amp service of the box?
Posted on Sep 08, 2009
  • 1 more comment
  • roberta3fan Sep 08, 2009
    Yes, I would say so, but it should trip the circuit breaker before it tripped the main breaker. unless the breaker that you have is for all the second floor and you dont have individual circuit breakers. If thats the case then yes the coffee maker is causing the problem. Its pulling more amps than your service has therefore it trips the breaker.
    A test you can do, unplug coffee maker and plug in something else in that plug, say vacuum cleaner and see if it trips the breaker.
    K, good luck
I have a built in Miele Nespresso coffee machine that shuts down (and trips the fuse board in the house) just as it has dispensed coffee. Anyone any idea what is causing this? Thanks
some liquid is leaking into the electronics or there is a motor gone
or some other leakage to earth of electricity
as i say can be liquid or a motor or a heating element
i think your model heats the milk so i presume some element has failed
its a job for the local approved service or see where you bought it
Jan 10, 2015 | Miele Coffee Makers & Espresso Machines
I have no power.
Hi I gather that you have checked every plug, valve, outlet and the electricity on the whole. Check if there is a valve in the machine that might have gone. Kolbrun
Sep 13, 2013 | Saeco Vienna Espresso Machine
Cuisinart DBM-8 coffee grinder started by itself.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Nov 02, 2012 | Cuisinart Supreme Grind DBM-8 Electric...
My Francis Francis coffee machine shorts out and fuses all the lights in my house. How can I fix this
Hi
I would say that it is probably your heating element. You need to install a GFI in your outlet to prevent an electrical shock, and that will prevent the machine from taking out the whole house, but it will take out anything that is on the same circuit.
Nov 14, 2010 | FrancisFrancis! X1 - Stainless Steel...
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Starbucks Aroma Grande DEAD - 200 degree overtemp electric limite
I have the same unit, but broke the lid to the caraf, so I'm elling my unit. Everything electrical works ... interested?
liquidboots@yahoo.com
Apr 10, 2009 | Starbucks Barista Quattro Coffee Maker
Blocked coffee despencer
I think you have to go to a Saeco service center to fix this, it can be the electric board.
Jun 25, 2008 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
215 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
