Question about Refrigerators
I am finding water in the bottom of the refrigerator and in the vegetable drawer. How can I fix that.....Thanks. Jan
  • capt2duck May 11, 2010
    Is this a top freezer model? or a side by side?
  • 34 Answers
The water is condensation from the freezer coil. The drain is plugged-up. You can sometimes pull the hose off from the back of the fridge and clear it. Try to clear it with air or hose and blow it out. Don't poke into the fridge with anything sharp, this could cause other problems. Some models you have to take apart the freezer section to gain access to the clog.
Posted on Sep 08, 2009
Why is there water in the chiller drawer on a French Door Refrigerator-Samsung?
We call that condensation from the moist vegetables, etc. in the chiller, natural occurrence.
Aug 21, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water in the vegetable and fruit drawers
You need to contact Samsung about this. they have a fix kit out to fix that issue. Its a common problem on the Samsung french door models.
Aug 05, 2013 | Samsung RF265AA Bottom Freezer French Door...
Water in the vegetable drawer samsung refridgerator
Thank you I have a rb 215 and having the same problems so yes this does help a lot... thank you t
Jan 22, 2012 | Samsung RF217ABWP (20 cu ft) Bottom...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
