Question about Car Audio & Video
I have a kenwood amp. kac-7285 dont turn on - Car Audio & Video
    Guru:
  • 1,326 Answers
Not much to solve this one. Either blown fuse if fuse is good and you have solid ground (check continuity), power and remote (use volt meter) your amp is no good!!!
Posted on Sep 14, 2009
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Keep popping fuse
you got short in the curcuit
Apr 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Doesn't turn on
You need to confirm that the B+ voltage isn't dropping at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
May 21, 2008 | Kenwood KAC-9102D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kac 7285 kenwood amp
Hi Steve,
Do you have wiring harnesses for the amp? If so write me and I'll instruct you in the proper wiring color codes for each souce.
Ed
NC Electronic
Mills, Wyoming
Jan 29, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
504 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
